Question about eMachines T6534 PC Desktop
E Machine T6534 fails every 6 to 9 months
My T6534 e Machine's motherboard had to be replaced after 9 months. It had to be replaced again 6 months later then 6 months after that and now for the 4th time the motherboard was replaced again. That is 4 new motherboards in 2 years 3 months.
They replace the motherboard but not the processor chip.
Is there a component that is causing the failures which repair is missing?
  • 3 more comments
  • sy ellin Jan 09, 2009
    I could envision noise or transients in the power supply or an intermittent component in the PS that finally caused the motherboard to fail. Thanks for the input.
    If the processor was bad would the computer still operate normally and then cause the motherboard to die?
    Each time the motherboard was replaced the processor was NOT. In other words what in the processor would cause a motherboard failure? If the processor was defective wouldn't it stop the computer from operating after replacing the motherboard?
    Thanks for the inputs.
    Hi Joed911,
    I was looking at latest received emails first and now saw your original answer/question. I did respond earlier and see that it was added to my original question "box". If you want even more info please ask me. I appreciate your help.
    Sy
  • sy ellin Jan 10, 2009
    Joeyd,
    In all failures there was no video. The last failure was interesting in that the processor fan was not turning. The processor heat sink was blazing hot. Turned off computer. Upon starting the computer the processor fan ran for 10 seconds and stopped. I turned off the computer and made arrangements to send it in for repair.
    Thanks again.
    Sy
  • Anonymous Mar 04, 2009
    i have about 10 systems all of this same proble I think this is a motherboard design faliure not of processor
  • JDTec
    JDTec May 11, 2010
    It definitely sound like either the processor or the power supply. In my 30 years of repairing computer, I have not seen this behavior. I would write a letter to eMachine Corp. Hopefully you have all the documentation.
  • eMachines Master
  • 4,338 Answers
You are correct in your deduction: If the processor is bad , none of the motherboard would have worked. You probably have a flaky power supply. What symptoms did the PC have when the motherboards were replaced? Lockups, no video, Blue Screens?
I would replace the power supply. The power supply could be checked for noise, but you need an O'scope to do so.
Posted on Jan 10, 2009
  • JDTec
    JDTec Jan 10, 2009
    The culprit was the CPU fan all along. I have seen that many times. Once the fan starts failing, it causes the processor to overheat, hence no video. And if it is not change in time it will and does cause the motherboard and processor fail. If this PC is still under warranty, I would have them change out the fan and processor. It is imperative that the processor be changed..
    BTW,That should have been the first thing your tech should have looked for.
    Good luck Sy..
    If I could be of further assistance, let me know.
    Thanks, Joe
  • 116 Answers
You need a new proceser
Posted on Jan 09, 2009
3 Suggested Answers
maxcloud
  • 20 Answers
SOURCE: motherboard failures. 4 times in 2+ years.
No Offense rebeleyes1, but they are not looking for an explanation of what most people think. Maybe an e-machine was something perfectly fitted to their budget. Anyways..
Sy ellin, Ive just done about 2 hours of research and what Ive found, honestly, You might not like it. A bunch of other computer technicans curse your board and a couple other boards by MSI. The problem is unknown, some people claim their PCI-E slot just stops working (the slot on the mainboard where you can install a video card). Others claim if you do a BIOS update it might help the problem before it happends. This is quiet interesting to me because I have the same chipset on my mainboard, The Nvidia 6100. My Video card just went poof...So, You and I just might have found the problem. The best thing I can suggest is replace the mainboard in your computer. ASrock mainboards are good, reliable, and cheap. If there is anything else I can help you with, dont hesitate to ask.
Chipset - Provides the CPU functions for a computer.
CPU - Processor Chip
BIOS - Electronic set of Instructions that a computer uses to successfully start operating.
rockitman187
  • 2559 Answers
SOURCE: e Machine T6534 fails every 6 to 9 months
This could be caused by the processor or fan,But very unlikely to be the mother board.
Posted on May 28, 2009
Emachine troubleshooting
This is typically caused by a power supply failure. Failing power supplies can have enough power to turn on lights and fans but not enough to start the computer. The power supply does not store any data so replacing it is a low risk and low cost effort. It is a very well documented process so search the Internet for "replace power supply" for more details. I hope this helps. Good luck!
Apr 29, 2013 | eMachines T6534 PC Desktop
I purchased my tx1019au new June,07. Global guaranty costing US$350. p/yr Jan, 08 WLAN card failed, HP Service center first declined to honor warranty telling me to mail it to the country of purchase....
The NVIDIA GPU (Graphics Processing Unit), located at U20, sharing the heatpipe heatsink with the main processor, has an issue with the reflow soldering to the motherboard.
If you can find a good PC board shop that mounts BGAs (Ball Grid Array parts, have them resolder the part to the motherboard.
Quanta Computers, of Taiwan, built the boards originally. (http://www.quantatw.com/Quanta/english/service/serviceinfo.aspx) They sell new MBs for $400. If you can get the NVIDIA part reflowed, it will probably cost less and work better.
The heat of operation causes the part to lift from the motherboard, causing separation of the solder joints, and intermittancy, or a complete failure with increased temperature - these parts are designed to run pretty hot.
Good luck.
Aug 15, 2010 | HP Pavilion tx1000z Notebook
Did these N200 0769 have a lot of faulty motherboards, my first Mboard failed within guarantee- and has again failed within 9 months of replacement.
I have a Lenovo 0769 and my motherboard is dead, it worked for 2 years and 3 month. Now it is out of warrenty and new motherboard costs almost the same as a new laptop..
Jan 04, 2010 | Lenovo 3000 N200 Notebook
May 28, 2009 | eMachines T6534 PC Desktop
P4/not booting up upon start
Hi try to open you chase and unistall all the additional slot cards and try to boot up, sometimes one of the slot cards fails and if that happens your machine wont start up until that slot cart is removed, thats how your machine protects it self
May 08, 2009 | Intel D865GBF Motherboard
Comp not reading montor
It sounds like the on board video has failed. I would try installing a video card on the motherboard. Then in the bios at start up, disable the on board video, so it will use the video card instead.
I hope this helps and thanks for using FixYa,
Eric
Jan 25, 2009 | eMachines T6534 PC Desktop
Motherboard failures. 4 times in 2+ years.
in my opinion e-machines are the bottom of the barrel and if they were giving them away I would have to pass, because they use the absolute lowest cost per unit parts = lowest quality parts in most cases... that is my opinion and not fact, sell it to someone and always buy the best quality you afford it almost always gives you more enjoyment for a longer period of time. Cheers!
Jan 09, 2009 | eMachines T6534 PC Desktop
EMachines T6534 motherboard replacement
motherboard replacement is depending on your current processor, memory, and video card:
Verify this site for your processor and motherboard matching.
http://www2.amd.com/us-en/Processors/DevelopWithAMD/1,,30_2252_869_9460%5E9461,00.html
(Note: copy and paste the url to your internet browser address bar.)
may this help you.
melnavz
Oct 04, 2008 | E-Machines eMachines Desktop PC
Laptop fails to start
bad mobo do u ever use it on your bed overheating died kiled power chips on mobo best to get new one mobo or sell on ebay its 1 yr warenty call maker
Jan 24, 2008 | Toshiba Satellite A135 Notebook
eMachines T6534 PC Desktop Logo
845 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
