I lost the instruction for programing the taylor 5610 handheld bodyfat monitor.
SOURCE: How do I get the detailed instruction manuel for the Taylor Bodyf
This link allows you to trouble shoot and download manuas directly with/from the company... I hope this helps. http://www.taylorusa.com/advantage/root/contact.html
SOURCE: what does TBW mean?
You don't specify where it is that you are reading "TBW", but In this context it is likely to mean either mean Total Body Weight or Total Body Water.
I don't understand why you have no manual or instructions. If my comment above does not help you, I suggest you visit the manufacturer's web site.
SOURCE: I need a replacement manual for my Taylor Body Fat
If you go to the taylor websupport site you should find one there, check the model numer though as I dont see a 5552 there. Once you select the product and go to the product page, you will see a link to the manual for the scale on that page.
http://www.taylorusa.com/catalogsearch/term/popular
SOURCE: how do i program the taylor body fat scale
From the Taylor web site
http://www.taylorusa.com/faq-scales
The easiest way to program the scales is to pull the manual up for the scale and follow the directions. The procedure does vary according to the scale.
In general the procedure is to tap the power or set button until it brings up the height and then hit the arrow keys until you get to the correct height. Hit the power or set after each entry usually height, age, gender, athlete mode. It will then beep and you will need to hit the arrow up until you see 1 (this is the memory number) tap the set or power and it will beep again. The scale is now programmed.
The general recall procedure is to hold the power or set button down for 2 seconds (or tap the up arrow) until the memory number goes up. Then just tap the power or set and it will beep. Then step on the scale to get the information. The weight will be first, then running zeroes, then thefat%, and finally water%.
Testimonial: "The website does not have a manual. Using 'search' or site map produces nothing. Another problem: scale reads only in cm and kg. Won't cycle to ft/lb."
SOURCE: say it in English,not British
1. Turn the unit on.
2. At the same time, press and hold the "G" button and the power button.
3. While continuing to hold down the "G" button, release the power button.
4. Release the "G" button.
5. If you have done this correctly, the unit will power on. This procedure will switch back and forth between lbs. and kg.
