Question about Fujitsu LifeBook S2020 Notebook
512 MB memory boards do not work in my Fujitsu Lifebook S2020
I wanted to upgrade my Fujitsu Lifebook S2020 from 512 MB total memory to 1024 MB total memory. When I installed new 512 MB memory boards to replace the existing 256 MB boards, the computer would not boot.
I tried to test the new memory by installing 1 new board and 1 old board. The computer did boot, but the memory check found only the 256 MB, and did not see the 512 MB board.
The label on the new 512 MB board reads:
PC2700 DDR SDRAM
64M x 64 512MB
512UJURTUNAC
The board is listed as SODIMM DDR333 200pin ram
Do you think there is an incompatibility between the 256 and 512 boards, or is there some other action that I need to take.
  • sethdogg1 Jan 09, 2009
    I am having the same problem with my lifebook on s2020. I did run my system on crucial.com and it told me I have a lifebook s6010. It recommended using pc133, which is much more expensive. I am stuck and tired of returning different types of memory to the store.
    Scholar:
  • 143 Answers
Frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Posted on Jan 09, 2009
  • Chinmay Joshi
    Chinmay Joshi Jan 09, 2009
    frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Helo, i want to upgrade memory on my ASUS CUBX-L motherboard. Manual says it recive max 4 x 256 MB of SDRAM. Is it possible to put 512 MB or bigger RAM modules?
yes you can put 512 mb of ram even 2 of it because the capacity of your board is up to 1024 mb of ram but make sure that it is an sdram and it has the same specification on whar is your manual indicate besides on the ram size.
Oct 14, 2010 | ASUS Intel 440BX Chipset CUBX-L...
Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
If new processor supports your old motherboard then you will upgrade system with your old motherboard.
If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
Thanks.
Happy to help you.
Apr 30, 2010 | Intel CPU
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
Help my pc is not detecting the correct amount of ram installed
Okay, first things first. IF the memory you installed is 1024 and you are using the on board video and it is 512 MB, you will only have 512 MB usable memory. This is because the on board video uses the installed memory to function. What ever the video memory is, subtract that form the total memory. If this is not the case, try re-seating the memory. If the numbers still do not add up then if there are four memory slots, make sure the memory is installed in the same color slots. Most desktops with 4 memory slots have two slots one color and the other two another color. Make sure both memory sticks are installed in the same color.
Jan 06, 2010 | Computers & Internet
Lifebook s2020 wont boot
try to replaced memory card or clean it first the pin of the memory card by using dry clothes
Aug 17, 2009 | Fujitsu LifeBook S2020 Notebook
Upgrade the shared graphic memory
there should be a setting in the bios to adjust the shared memory with video.
Feb 02, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
I want to upgrade my HP BA 600 Mother Board`s RAM Capacity
Most likely your MB is too old for this upgrade although there is a chance you could flash your bios (reprogram your computer's brain to accept the new memory providing hp has a flash for it).
here is a link for the latest bios flash for your computer, use at your own risk.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=32895&swItem=vc3903en&prodNameId=20305&swEnvOID=54&swLang=13&taskId=135&mode=4&idx=0
good luck.
Thank you,
agadycom
Nov 27, 2008 | HP Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
I have an hp pavilion ze4430us laptop. I am wanting to know how much memory that it will support. I am wanting to upgrade from 512 to as much as it will support.
hi,
The max memory supported by your computer is 1024 mb..
(1GB).
You can verify it here in this link
Also when you do this the already existing 512 MB may be gone without any use if they had provided you as 256+256 in seperate slots
Apr 11, 2008 | Computers & Internet
Fujitsu LifeBook S2020 Notebook Logo
440 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
