Question about Proscan 32LA30Q Television
My xbox 360 is connected through the component 1 input but it still reads "no signal"...i have a proscan 32lb30q purchased from circuit city 5 hours ago...i have tried to connect the xbox using the vga input as well with the same result
  • shneeks Mar 15, 2009
    i got the same problem, my 360 and ps3 don't seem to work on this tv.. is there anyone who knows how to fix this issue??
I assume the xbox works on other tvs.
Posted on Jan 09, 2009
Proscan tv
Check that you're on the correct input and the Xbox 360 is sending the correct signal (be it 720 or 1080).
Sep 08, 2014 | Proscan Televison & Video
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
What's your problem?Im trying to hook up my xbox 360 to my JVC 27 inch TV, I installed the yellow to video input and the red and white to audio input and all get is the audio and no video. What am I...
Troubleshoot.
1. Ensure yellow is actually connected to an "input" slot.
2. Ensure TV is set to the correct input source.
3. Ensure your yellow, white and red RCA connectors are grouped in a single input source to TV. Sometimes the "component" and "composite" inputs are grouped closely together.
4. Consult the TV manual for hookup instructions.
5. Conduct a continuity test on the yellow xbox wire with a multi-meter.
Oct 04, 2011 | Sega The Club - Xbox360 for XBox 360
How to conect a PROSCAN MODEL 32LB30Q to a curtis DVD1098B
Buy an HDMI cable, plug one end to the Curtis DVD1098B's HDMI Output, and the other end plug into the TV's HDMI IN 1, or 2.
Using the remote control, and the assistance of the manufacturer's manual change the tv's input to HDMI 1, or 2 respectively.
Verify the input, and output of each device if you do not want to use HDMI, then using the same process connect the output of the DVD to the respective Input of the TV, i'm unsure of the TV's input but the television appears to support Component, RCA, and Coaxial.
Mar 01, 2011 | Computers & Internet
Wont read games only reads dvds
This is going to be a bit long -- but very detailed, so please read it carefully. There are several reasons that an xbox 360 system will have problem reading discs. The error messages also vary from unreadable disk, no message at all but the game skips, "please insert disc in a 360 console" to "open tray." There are a few reasons this may happen:
1.Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser.The laser is the part that actually reads the disc. The reality is...with all the hours and hours of game play, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
http://store.richspsxparts.com/xb360ac.html
3.Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything,including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock.The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
XBox 360 parts: http://store.richspsxparts.com/xb360ac.html
DVD Drive Swap Info: http://store.richspsxparts.com/imnooninxb36.html
May 15, 2010 | Microsoft Xbox 360 Pro System Console
BT HomeHub wireless router which cannot connect to the XBox 360
your router may have incorect connection settings. what i mean is that your router may have security on that rejects connecting to adapter. check if the xbox can connect to the internet via ethernet cable. this will tell for sure if the 1 the adapter cannot read the signal or 2 the adapter is not able read any signals. to test if its the adapter, try searching for other signals.if you find any other signal it means your router. is rejecting to send the signal to the xbox.
Feb 01, 2010 | Microsoft Wireless Network Adapter Xbox...
Xbox 360 not reading discs
1. Bad disc. Check the back of your disc for scratches. If it looks good (or plays fine in another console), then the disc is probably fine. Also-- try more than 1 game to be sure.
2. Bad laser. The XBox 360 has a DVD drive very similar to a PC's DVD drive inside. The drive contains a bunch of parts including a few motors and gears and a laser. The laser is the part that actually reads the disc. The reality is... with all the hours and hours of gameplay, lasers do eventually wear out. The laser isn't very easy to replace, but it is replaceable. You can find any and all XBox 360 lasers at the following website:
3. Bad DVD Drive. Sometimes other components inside of the DVD drive can become bad such as the motor that spins the disk, the motors that open the tray, etc, etc. You can get a new DVD drive to just replace everything, including the laser, in one shot but there is a catch. The XBOX 360's DVD drive is tied to the motherboard using a software lock. The easiest way to overcome this lock is to buy the exact same manufacture DVD drive that is in your system now, remove the circuit board from the old DVD drive (which contains the software key) and transfer the circuit board into the new DVD drive that you purchase. If you do this simple procedure, there is no flashing involved. The following website carries DVD drives and also provides instructions on swapping the circuit board from the old drive into the new one.
Nov 17, 2009 | Microsoft Xbox 360 Console
Trouble with 360 and hdtv
The cable your refering too are called Component leads.
The red and white are for your audio and the remainder are the video. All you need to do is connect the component leads matching up all the colour in the correct ports then using your av/source button change the tv to component
You will still have to connect the red and white audio cable to the tv as well.
that should sort your xbox out.
cheers
Little Dish Fitter
Sep 18, 2009 | Proscan PS36700 36" TV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
Exp hd & modchip - not reading 360 games
I think there must be a problem with the processor, i have known people in similar cases. If you got the warranty from where you got it, (ex. Circuit City, Best Buy) then go take it back and they will 90% of the time give you a new one. If you dont its okay because Xbox 360 has a three year warranty given to every owner free. Call Microsoft/ Xbox customer service and they will send you a empty box in about 3-5 days. It will take them about a week or two to fix but it will work perfectly as did mine.
Dec 28, 2007 | Microsoft Xbox 360 Console
Proscan 32LA30Q Television Logo
260 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
