Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Cant Figure Ou What Hose Goes Where?
I have a Bissell Pro Heat X2 model #8290, i let someone borrow it and when i got it back it would not release any solution on to the carpet so i figured if i took it apart and cleaned all the hoses out and ran some hot water through it then it would possibly clean out what i thought was just some dryed up soap or something well the problem now is i took all the hoses off and cant figure out where they hook back up to. I have sort of an idea being the lenth of them only reach to certain parts but some have two or three hook-ups and i am just lost and frustrated. I tried a couple of ways but it just constantly pushed out water, so i figured maybey the user guide/manual would help but it doesnt show anything abut the hose diagram and i just hate to throw it away because of such a easy fix, Please email me back with any answer or suggestion, thanks T.S.
  • 6 Answers
I don't know if its the same machine but I found this site, it provides a link to a picture of the tube routing:
http://c.managemyhome.com/mmh/answers/Answers.action#l4q145526
Posted on Nov 18, 2009
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Try this link - the PDF manual here should help. Unfortunately there is no page 18 which I imagine would be most useful - however the other photos should be good enough
www.bissell.com.au/images/IncludeContent/Service_Center_Help/Upright_Deep_Cleaner_Repair_Guide.pdf
Tony
Posted on Jan 18, 2009
  • tmarshall57 Jan 18, 2009
    By the way - if the unit will not dispense fluid from the main unit (but does dispense fluid using the hand tools - the most likely problem is a blocked heater. This is contained in the handle. The heater unit can be easily dismantled and cleaned. The heater is made of aluminium which corrodes if the unit is not washed out with clean water.
    Tony
Bissell 9300 m pro heat turbo 2x . i need the hose diagram for my machine please
I have had problems with the little red clips that squirt the water getting clogged, tiny little holes! I had to remove them and use a needle, then blowed them out with air compressor. I am also trying to find a diagram for this 9300-M model but cant find one.
Aug 26, 2010 | Bissell Vacuums
Cant figure out how to use the bissell pro heat carpet cleaner
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
54erw
Jul 25, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell pro heat steam carpet cleaner, not releasing water.
That means that you need to replace the pump belt. Here is the belt you need and a manual you can view:
Bissell 7901 Belt and Manual
Mar 01, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell Pro Heat 7901 will spay through hose but not the floor and red flow indicator will not spin. So we took the housing off and after unclogging a hose running to the hearter, my husband unhooked the...
I borrowed my friends bissell to clean my carpet. It's the 7901. He brought it over and told me that it only sprayed out of the attachment hose. He said he couldn't figure out what was wrong. I'm no vacuum technician but, I am a mechnic. I decided to open her up and check it out. After about two hours it was back together and working. The reason I replied to your e-mail was because we have the same problem. I couldn't find an answer to this problem on this site so I will tell you what I found and hopefully it will help you. In removing the cover where the red heating light is, there is the heating unit for the water. In my case it is silver and it will get very hot so be careful. Notice that there is two water hoses connected to it. I removed this heater and found one of the connectors where the water hose goes was clogged. I took the back off the heater and used my air compressor to blow out the connector, and sure enough something flew out. Hope this helps. brian.small@bobstgroup.com
Sep 04, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
My Bissell Pro Heat 2X will not release water or
its probably a solenoid that controls the flow to the floor, take it to a bissell repair center, because its not an easy fix.
Jul 02, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Cant put belt on {goes to brushes}
bo to bissell.com and go to tech support maybe you can find it there,or just type the brand and model number followed by manual in your search browser and you will find all kins of places you can get it
Apr 13, 2009 | Vacuums
Cant put the roller back on right!
The user manual has a diagram and instructions and is available online.
I could try to walk you through but their diagrams and instructions are pretty good.
A couple tips....the small red plate screws in laying flat and the largers one slides in sideways.If you try to match the screws holes up it may help.
Also the first time I had troubles we called Bissel and someone helped us.
Nov 30, 2008 | Bissell 8910 ProHeat Clear View Upright...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
322 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
