Question about Acer Aspire 1522LMi-XPP PC Notebook
Aspire 3000 fan not working
I've had my Acer Aspire 3000 for a pretty long time now. I'd thought it was beyond any kind of repair after my siblings started using it and proceeded to clog it up with a bunch of stuff. I reformatted it, and it works like a dream now.
Except the fan doesn't work at all anymore. I've taken it apart and found the fan very easily. I used air duster to clean it out, and even a vacuum hose and a brush. The fan is probably cleaner now that it's ever been. In any case, at one point while I was looking at the fan and its port, the fan started up, but quickly stopped working a split second later. I can't tell if there's a problem with the fan itself, or just the port that the fan plugs into.
In either case, what solutions might there be for both instances?
my Acer Aspire 1520 was working all right but needed reformatted, after doing so the fan would not run any more, i cant reinstall windows because it gets hot and kicks off half way through the installation
    Problem Solver:
  • 11 Answers
As the notebook is a old one.Its better to replace the fan
Posted on Jan 09, 2009
I keep the message General Protection fault with a black screen when I turn my acer aspire 3000 on and it won't go past that screen/What can I do to fix it?
To repair corrupted system file/s, boot up with the Windows installation CD then -
Press R to repair when instructed.
Press 1 or Enter to repair the C:\Windows folder.
Then type chkdsk /r and then press Enter.
The repair process will take quite a long time.
Jun 16, 2012 | Acer Aspire 3000 Notebook
ACER ASPIRE 3000 gets power off after some time automatically
If the laptop shuts down by itself and deosn't boot up again after some time, then the problem could be an over heating problem. The CPU shuts down when it overheats (thermal shutdown) and it is usually caused by a faulty fan and or the fan and heat-sink is clogged with dust.
Check the fan and if it does not spin freely then replace the fan and or remove the dust from the fan and heat-sink assembly.
Oct 12, 2009 | Acer Aspire 3000 Notebook
Computer shutting down
  1. Be sure your power supply is working and charging battery
  2. Allow battery to full charge
  3. Be sure PC is cold not hot or warm
  4. check if before shutting down PC fan is starting: if not starting PC thermal protection can be triggered and your fan out of service.
Jan 14, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Most fans run on 12volts DC, remove the fan and connect it to a 12volt power supply, if it spins freely then it is OK and the fault is with the laptop, if not replace it.
Dec 30, 2008 | Acer Aspire 3000 Notebook
Acer aspire 3000
Could be a bad memory chip or a hard drive crash. Can you hear the hard drive engage? If so, is there any clicking or dull thunking sounds? Both of these are indicators of a hard drive failure.
Jun 21, 2008 | Acer Aspire 3000 Notebook
Acer Aspire 3680-2022
The cause can be either the motherboard is sensing the proccesor is overheating, but it isn't and is running becausse it thinks it needs to be cooled, which is not right, or the processor is actually running too hot, so check around all the vents, side and underneath and carefully hoover with an attachment around them, if it still continues, then a specialist repairer is requird to check board and processor.
Apr 29, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 1522LMi-XPP PC Notebook Logo
108 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
