Question about Samsung S860 Digital Camera
Proper memory stick
On my s860 digital camera i bought a 1gb memory stick inserted it correctly and when i go to delete a picture it says no image, and the meter hardly is filled either. so what am I doing wrong.
  • krpolzin Jan 09, 2009
    this is the second memory stick that i have tried. the memory stick indicator doesn't fill up like the battery indicator. is it my cmaera?
    Genius:
  • Samsung Master
  • 1,673 Answers
You should contact the manufacture of the camera. There are some models of memory sticks that have compatibility issues with specific models of cameras. Outside of this, the memory stick may be defective, or there is a defect with the camera.
The odds are in your favor that the fault is the memory stick more so than the camera.
Another rare issue is that the data on the memory stick is corrupted. If there are no issues between the memory stick and the camera, most of the time re-formatting the memory stick should fix the fault.
Jerry G.
Posted on Jan 09, 2009
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
What if I erased the...DMCI folder in my memory card? I can no limport my pictures in my desktop because there is nothing in my memory card..
It is not recommended to erase the DCIM Folder in the Camera as this is the root directory in the Digital Camera which contains DCIM (Digital Camera images). This DCIM Folder contains the sub directory where the images are getting saved. if the folder is deleted manually from the Computer, then the Camera will not recognize the Memory Stick inserted and the Computer also. if the folder is deleted or edited, then I suggest you to Format the Memory Stick again in the Camera using the Format option in the Menu of the Camera.
Thanks for using Fixya.
Jan 27, 2011 | Cameras
Internal memory is full on our M580 Can not toke pictures
I copied this from Kodak website Good Luck!
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card?
Follow these steps:
On the camera, press Review and then Menu.
Select Image Storage.
Change to Internal Memory.
In the menu listing, scroll down to Copy, and select OK.
Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
NOTE: You can also use a card reader to transfer picture files to a memory card. For more information on card readers and memory cards, go to KODAK Memory Cards
Sep 05, 2010 | Kodak Easyshare M580 Digital Camera
Says memory is full when its not...
1. Use a card reader and download the 8 pictures to your computer. 2.With no card in the camera, go into the menu and find "format" or "initialize" and follow the on-screen instructions. 3. Go into the menu and see if your camera has an entry for "reset". If it does, reset the camera. 4. Insert the memory stick and do the "format"/"initialize" thing again. Everything should work properly now.
Jul 26, 2010 | Sony Cyber-shot DSC-W70 Digital Camera
How to delete all photos in memory
Formatting a memory will delete all the photos including the protected images. Download important images to your PC before formatting the memory
1. Go to Settings (it will prompt you to some options)
2. Go to Format
[No]: The Memory Will not be formated.
[Yes}: A window for confi rming the selection displays.
3. Select the [Yes] menu.
2. A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a 3. [No Image!] message will appear.
Apr 08, 2010 | Samsung S860 Digital Camera
Camera says no image
contact problem of the card/card reader try to clean chaque for the proper contacts.
Mar 08, 2010 | Samsung S860 Digital Camera
How do I retrieve deleted accidental photos?
uFlysoft Photo Recovery for Windows is an advanced utility that recovers lost images, audios, video clips, and pictures from almost all digital cameras, memory cards, hard drives, memory sticks, USB flash drives, and various others. The easy-to-use Photo Recovery utility is available for both Windows (Windows 7, Vista, XP, 2003, 2000, and 2000) and Mac (Mac OS X 10.6 (Snow Leopard), 10.5 (Leopard), 10.4 (Tiger), and 10.3.9 (Panther)Use the Data Recovery for Mac to acheive Photo recovery on Mac) operating systems.
Aug 18, 2009 | Samsung S860 Digital Camera
Sony Memory Stick ProDuo Memory Problem
PLEASE FORMAT AND SCAN IT TO REMOVE ANY THREATS
Oct 16, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Deleted photo recovery from cameras internal memory
Please try this, turn on your camera, insert a blank memory stick, slide the side switch down to the lowest point, should say “No file in this folder” click on menu, click on Setup, use the arrows and go to Memory Stick, choose “Copy” choose “Album” the “OK” this will copy all you pictures from the Album in your camera to your memory stick.
Hope this helps
J
Apr 12, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
My Pictures just vanish!!!
Yes, you are possibly to recover the lost photos with so-called photo recovery software. Well, since you failed to mention the OS you are running, I'll recommend you have a try of Wondershare Photo Recovery, a program equipped with both Windows and Mac versions. For Windows OS, download from here. If you are running Mac OS X, get the program from this link.
Step-to-Step Instruction:
1. Download and install the trial version on your computer, then connect your camera memory card to the computer (I assume you are using Windows). Start Wondershare Photo Recovery and select the drive letter that assigned to camera memory card.
2. Then choose the file type (all, photo, video, music) click "Star Scan".
3. Now the scanning process will start automatically to look for the deleted items. You will then get a list of all recoverable ones.
4. Preview the photos. If your deleted ones are found, then you need pay to get the activation code. And click "Recover".
Tips:
1. Take the free trial version before you buy.
2. Before your deleted items are recovered, do not take more photos or videos.
I hope you good luck,
Jan 04, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Samsung S860 Digital Camera Logo
24 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
