Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD 52525 lamp replaced, no picture, red light
I saw that you offered insight to several folks regarding the Mitsubishi WD-52525 and recommended the V26 DLP FMT PWB repair Kit if you replaced your lamp but were still getting the solid red "Lamp" light. How do we find out if the capacitors are our problem and find out if this will fix the issue?
Thanks,
John Lewis
  • 3 Answers
You have to take the TV apart. Pull the electrical chassis out and look for bad electrolytic caps on the boards. The red LED probably means the 2 - 3300UF caps on the power supply board are bad. You can tell if they are bad by the fact that their tops are puffed up and they may or may not be leaking brown fluid. Compare them against the other caps on the boards and you will see how they have flat tops.
BUT before you take the TV apart you can check the error codes by pushing "menu" and "Device" at the same time and holding for about 10 seconds. The status light will blink two numbers. ex. one flash pause two flashes is 12 Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
or use this table -
You can buy replacement caps from Mouser electronics online. There are plenty of solutions detailing how to do this already posted.
Posted on Jan 11, 2009
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
I replaced the lamp in my WD-52525 and I still have a solid red light and no picture......is there any instruction on how to replace bad capacitors?
hello make sure the lamp is fitted securely and the lamp; cover as well this it due to the safety switches hope it helps
regards
shaun
Jan 24, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD-52525 and replaced the lamp.
We have runn in to this with this type lamp, And we are a service center so we do hundreds of these. We too have had bad lamps straight from the box so best guess would to take the lamp back Mitshubishi will warenty the lamp for 90 days so act fast
Dec 17, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wd 52525 red lamp light on but new lamp isn't
HI. the actual issue will be a failed ballast device. replacing this damaged power regulator will fix this issue. you can order your new ballast by clicking the link below.
Ballast(Click here to order)
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525
You have a bad DM Board. You need to replace it. Changing the capacitors will not cure the problem. Completely replace the entire board
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in. Rear Projection - no picture lamp light goes red
yes the capacitors go bad on the power pwb . You can get the V26 Power PWB repair kit at the following link which has the replacement capacitors and instructions. Heres the link its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Dec 03, 2008 | Televison & Video
WD 52525
HELLO . IT SOUND'S LIKE YOU NEED TO REPLACE THE BALLEST .!! AND THAT SHOULD FIX IT.!!! "GOOD LUCK"
Aug 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Shuts off, shows red lamp light even after replacing lamp
maybe your problem is in the power supply circuit of your tv,but then try to replace the flyback first maybe there is no high voltage coming out on the cap.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,563 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
