Question about Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus not dispensing coffee
We can hear the machine clicking loudly and it says its brewing but nothing comes out and then the ventilate comes up. We primed the machine prior to running it. Any suggestions?
  • 1,618 Answers
Try setting the grind to the coarsest setting, if you still have the same problem, then descale machine.
Posted on Mar 09, 2009
Grinder works fine. Water pump sounds normal but no water flow when in rinse mode, brewing coffee or in hot water dispense mode. Something is clogged???
Run a simple cleaner through your system without coffee. Pour in white vinegar 4:1 ration. Brew this maybe up to 3 times. Should clean your clog.
Feb 02, 2016 | Saeco Magic Comfort Plus Espresso Machine
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block).
Sep 14, 2014 | Saeco Magic Comfort Plus Espresso Machine
Coffe Machine Saeco Magic Comfort
the coffee beans grinder is too fine .Turn to next number,
Oct 29, 2013 | Saeco Magic Comfort Plus Espresso Machine
Hi, I have a Saeco Magic Comfort Plus. When I press the button to brew coffee, the coffee is spilling into the dregdrawer rather than thru the spout for the coffee. It's not water, but actual coffee is...
Sounds like your thumbscrew is getting stripped. Its the same for all the older machines.
If its only partially stripped it slips up and allows the water to enter the brew head pocket where the thumbscrew is and the spill over into the dredge drawer. Check the brew head for water.
Aug 14, 2011 | Saeco Magic Comfort Plus Espresso Machine
Hi, I have a Saeco Magic Comfort coffee machine which displays the following message when I switch it on 'Brewunit missing'. Hope you can help. Cheers
Open the door on the right. The brew unit is the thing with the handle that has the "press" on it. You need to push on the upper left side of the brew unit until it clicks. There is an outlet spout on the opposite side of where you are pushing. It goes into an intake port that needs to be lubed(food gade only), so the outlet spout will slide in without pushing back. That should take care of the missing brew unit.
Apr 17, 2011 | Saeco Magic Comfort Plus Espresso Machine
Saeco magic comfort plus - brew unit miss??
Check the micro switch that the brew unit hit when it enters the machine. Sometimes the lever arm on the switch breaks off, and the switch will no longer work. Click the link for a picture of the micro switch.
Micro switch for saeco and gaggia machines
Jan 15, 2011 | Saeco Magic Comfort Plus Espresso Machine
The espresso coffee is taking forever to fill a
When you push the water button, how is the flow? If it is OK its not your boiler. What happens when you press the pre-ground button but don't put any coffee in. If it brews correctly( not slow) your grind is too fine. Just push the lever below the bean hopper back 2 clicks. If you are still brewing slow you may have a plug of coffee in your brew head. A pinch of automatic dish washing detergent in the brew unit funnel, then push the pre-ground button again. This can break up the clog and allow a normal brew.
You don't want to use vinegar in your machine. It leaves a taste for a while. Citric acid is what you want.
Nov 04, 2009 | Saeco Magic Comfort Plus Espresso Machine
Brew unit missing?
Make sure the brew unit fits in place, press the "press" button when you put in the brewunit.
Let me know if it works.
Aug 06, 2008 | Saeco Magic Comfort Plus Espresso Machine
Saeco Magic Comfort Plus Espresso Machine Logo
318 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
