LG wm1832cw shaking bad in spin after move
Hiya,
The movers moved our washer, an LG wm1832cw, but neglected to use the shipping bolts that were on top of the washer. It is now shaking pretty bad in the high speed spin cycle.
What do i do about it? Is there some standard method of fixing it that is fixable by a capable user?
Is the service manual available online?
  • 640 Answers
Manual,,lg.com...but befroe youdo that,,put the unit in spin ,,get a small wrench or the wrench that came with the installation pack..now when unit goes into high spin the fastest spin,,tighten the lock nuts on the legs one at a time dont turn the leg itself,,just the lock nut on the legs,,it might take two spin cycles but you will get it ..tighten all the way uop to the base,,,onthejob
Posted on Jan 10, 2009
How can we fix the vitiation, noise, and movement on a front loader that was just moved to another home?
These units spin at a high RPM. With just a few clothes, especially jeans and sweat items, the drum is off balance and therefore will have the above symptoms. These newer units weren't designed to run just a few items. It's a full load or nothing. It's an energy conservation thing.
Sep 26, 2014 | Kenmore Elite 45986 Front Load Washer
I recently moved and the movers removed two bolts from the back of the machine...should I replace those bolts
No do not replace the shipping bolts. I assume you have a front loading washer. The tub is secured by bolts during transport. Then they have to be removed so that the washer will operate properly without damaging the machine.
Many machine manuals are available online. For example, LG washers manuals are available at their site and under more information for models sold by Home Depot (http://www.homedepot.com/Appliances-Laundry-Clothing-Care-Washers-Front-Load-Washers/h_d1/N-5yc1vZ1xr5Zbv6h/h_d2/Navigation?langId=-1&storeId=10051&catalogId=10053&omni=c_Front%20Load%20Washers). The LG front loading washers use 4 bolts with retainers. If they are not removed, the machine will have severe vibration and noise. The vibration can damage the unit.
I hope this helps.
(if you have an top loading washer, shipping bolts are less common. If you provide the model of the washer, I'll see if it is one for which I know the shipping instructions.)
Dec 12, 2010 | Washing Machines
Recently moved and now my washer sounds like it is going to take off!
Hi.
If you hear an high pitched noise or rumble that becomes louder when spinning at speed, then you may have dislodged the drum bearing or broken the drum bearing spider.
The part is located at the back of the drum.
Dec 03, 2009 | LG WM-2277HW Front Load Washer
Lost or not retained shipping bolts
Just looked at mine (we had to order them before the military would move ours). They are two different sizes, have a long plastic washer (lengthwise), and are - believe it or not - like a lag bolt on the end! A hybrid mess meant to force us to order them, if you ask me. Not sure you should try rigging it, best if you order them, you'll see what I mean when you get them. Sorry, we were in the same boat too. Wish I never bought this LG, but that's for another post.
Jun 30, 2009 | LG WM-2077C Front Load Washer
Clothes mover of whirlpool top-loading washer is loose. Agitates.
You need to replace the agitator dogs inside the clothes mover (agitator). take of the top then the cover, remove th bolt and take the top half off. you should see four "dogs" that need to be replaced.
Jan 25, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Washer is shaking violently when it is time for the spin cycle
Check to see if all shipping blocks and bolts were removed. Refer to installation and setup instructions for your model.
I once moved into an apartment furnished with washer and dryer. The washer had worn holes in the vinyl flooring and a neighbor said the previous tenant made her son sit on the washer to hold it down. I investigated and found the shipping bolts were still in place. The tub, which is supposed to be able to swing, was rigidly held in place, so the entire machine danced around the room!
Jan 10, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Move
you can reuse the shhipping bolts but getting them back in is a royal pain in the but. if you have help you can have someone open the door to move the tub around so you can line up the shipping bolts to screw them back in. it help to take the top off the washer to help you see where your putting them.
Nov 27, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
349 people viewed this question
Top Washing Machines Experts
