Question about Hifonics Titan TXi 6006 Car Audio Amplifier
Problems with my txi 6006 amp
I recently purchased a hifonics titan txi 6006 amp and i have it pushing 2 alpine type r subwoofers. at first, the amp pushed the subs verrrrry hard and i was extremely pleased with its performance. now, about a week later, the amp seems to be over powered very easily, and is not pushing my subs nearly as well as they were nor as much as id like it to (ive had to turn down the amps settings).
is there anything i can do to get the performance of my amp back to where it was? or will i need a more powerful amp? i understand the amp temporarily over heating and not pushing the subs as hard, but how can it so suddenly stop pushing them like it was.
Check all connections then check the subs voice coils to make sure there not burnt smelling, or burnt looking.then check the cars charging system you might have to add an extra battery,and or cap.
Posted on Jan 09, 2009
I have a alpine M500 amplifier running a hifonics brutus subwoofer and i think it is blown. I don't understand how this could happen as the amp is only pushing 500 rms and the sub takes 600 rms. I got no...
Hmmm, let me see here. Did you mean to say you have TWO subs connected to this amp? A single sub can only be wired in series with the amp. Even if you have a capacitor wires in parallel, the capacitor is not a load, but a souce equivilant, and therefore can be merged with the amp as a single source when put on paper.
When they say a sub or amp is so many watts rms, that means that the device can function safely, without worry of failure. THERE IS NO LEGAL METHOD FOR DETERMINING THIS NUMBER AND NO REGULATIONS ON VARIANCES. Having said that, if an amp is 500w rms, it could very well push double that for long enough to blow your speaker. It all depends on how much power went through that speaker. So since you have a 4 ohm speaker, not two, and it would actually act like a two ohm speaker if you put another one in parallel because 4||4=2ohms equivilant. never never never, turn the bass all the way up if your gonna beat loud. Low frequencies draw lots of power and can damage your system.
you can tell if your speaker is blown by turning the volume to a medium listening level and placing your hand on the cone. you will hear a crackling sound if it is blown
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Jun 05, 2010 | Hifonics Brutus BX12D4 Car Subwoofer
Is right use the amp with the x-over in lpf and also with and impedance of 2
If your amo is a subwoofer amp yes you want a LPF. Low pass filters are capable of passing low frequency energy. As far as the impedance of your amp goes check with the manufacturer for proper the proper load. What speaker config do you have?
2 DVC 8 ohms in parallel (voice coils) then series (speakers) are 8 ohms
2 DVC 4 ohm - in parallel (voice coils) then series (speakers) are 4 ohms
DVC is dual voice coil
Impedence for parallel is (Z1^-1+Z2^-1)^-1 or 1/((1/Z1)+(1/Z2))
Use those to figure out parallel impedance, series you just add them together.
Dec 21, 2009 | Hifonics Titan TXi 6006 Car Audio...
I have 2 alpine r type 12's hooked up to a kicker crossover and a NRG 2200 800 watt amp. they are wired series and parallel. when i turn it up the subs sound like the are fluttering. what is going on.
well my friend either your amp is not powerful enough to push your subs or you have a sub that is shorting out cause i just had the same problem with my 2 15 kicker cvr competition subs
Nov 04, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
NOT SURE WHAT OHMS SUB I NEED!
if you get the 4ohm you can wire it to run a 2ohm an the kenwood amp will push 900 watts at 2ohms.they say it can push up to 1800 watts,that would be at 1ohm.that kenwood runs 500 at 4ohms an 900 at 2ohm.if you need help wiring the sub or anything else let me know bertman285@hotmail,com Max Power Output 1800W Power Output 4 Ohm [14.4V] 500W x 1 [20-200Hz, 0.5%THD] 2 Ohm [14.4V] 900W x 1 [100Hz, 1.1%THD] Bridged[4 Ohm] -
Oct 09, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Has my subwoofer been blown?
hook ithe sub up to a 9volt battery and see if the woofer moves... You will not dammage the suub testing it this way.
Mar 23, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Will a sony 1000 watt amp model # xm-1652z run 2 dvc 800 watt rms subs?if so,whats the best way to wire them to this amp?thx
personally i wouldnt use a sony amp for powering anything but,however if your going run it what i would recommend is if the speakers are at 4 ohms then run in series per speaker then put the speakers in series as well so you will keep your 4 ohms then run the amp in mono,however just to let you know that amp will not push fubars enough to really make them thump my advice is to goto http://www.sonicelectronix.com  if you have 200 dollars you can get a nice  Hifonics TXi 1508D that will push those monsters quite well thats 1 ohm stable and will barley get warm even after hours of thumpage,also if your running subs monoblocks are the way to go hope this helps you out.
Feb 21, 2009 | Power Acoustik Power-Acoustik FUBAR-12W...
Problem with my amp
then use it as a paperweight...seriously, you prolly blew the jensen speaker, you prolly damaged the amp
May 15, 2008 | Hifonics Titan TXi 6006 Car Audio...
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
No sound to speakers
is the sub dual or single?check sub first then try disconnecting all power including ground for 20min to discarge caps some amps mute if driven hard at low impedience .
Jul 01, 2007 | Hifonics BX1500D Car Audio Amplifier
Car Audio & Video Logo
152 people viewed this question
Top Hifonics Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
Are you a Hifonics Car Audio and Video Expert? Answer questions, earn points and help others
