Question about Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer
F dL symbol on Whirlpool duet HT
The symbol F dL comes on when I try to start the wash cycle. It make a clicking sound when I hold the "hold to start" button and then flashes the F dL. I have tried unplugging the washer. I have a whirlpool duet HT
Thanks.
    Sergeant:
  • 222 Answers
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
Read more: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Whirlpool Duet Front Loading Automatic Washer Fault Codes#ixzz1goKMAuZ7
Posted on Dec 17, 2011
    New Friend:
  • 88 Answers
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Posted on Jan 11, 2009
Problem with whirlpool w/m adp4737
Whirlpool Duet & Duet HT & Kenmore w/110 model prefix Frontload Washer Error Codes-OLDER
  • F/H--No water detected entering machine or Pressure switch trip not detected
  • F/02--Long Drain
  • F/05--Water Temperature Sensor Error
  • F/06--Drive Motor Tachometer Error
  • F/07--Motor Control Unit Error
  • F/09--Overflow Condition
  • F/10--Motor Control Unit (MCU) Heat Sink Thermal Trip
  • F/11--Serial Communication Error
  • F/13--Dispenser Circuit Error
  • F/14--EEPROM Error
  • F/15--Motor Control Unit (MCU) Error
  • Sud--SUDS LOCK (Overdose of Detergent detected during the Wash Cycle)
  • F/dL--Door Lock Error
  • F/dU--Door Unlock Error
Jan 01, 2012 | Washing Machines
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Jun 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code...what is this problem?
F30 is a dispenser failure code on the Duet Sport washer.
It means the dispenser motor will not go to the proper position.
Remove the top of the washer and inspect the dispenser linkage to see if it is binding up.
Post back with what you find and we will check from there.
Thanks/Mike
Nov 03, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
596 people viewed this question
Dan Webster
Dan Webster
Sal De
