Question about Dometic RM2652 Refrigerator
My fredge rm 2652 not working
My fredge is not working neither on a/c or LPG. No leak is present . I think is the circuit board in the back part. No flame is present when change to LPG. Fredge was working on a/c and apparently a power failure occurs and not work after that.
I try to verify the circuits in the circuit board but there are sealed . fuse are ok.
any idea?
Mike
Refrigerator Model no: RM 2652
Refrigerator prod. no: 921144002
  • Anonymous Feb 13, 2009
    I have the same problem. Probably the circuit board.
  • sunshine3444 Feb 13, 2009
    just purchased (2-12-09) Keystone TT with dometic fridge RM2652. 120 a/c outlet has power. fridge does not get cold, no noise from condenser. propane tanks empty. have not tried that mode yet. Any advise?
    tmanalio@yahoo.com
Check power at circuit board j4 should have power
Posted on Jul 25, 2012
    Habit-Forming:
  • 20 Answers
Between 1993-1996 dometic used a yellow epoxy filled circuit board that went bad pretty quickly if you have the yellow filled circuit board rather than the green one it is most likely the circuit board
Posted on Feb 20, 2009
Dometic rm 2652 refrigerator will not cool
if voltage to unit remove thermistor let run if ok replace thermistor if not see if chimney hot if not heater element if doesn't work on LP bad control board
Nov 18, 2013 | Dometic RM2652 Refrigerator
I have a dometic rm 2652 in a 2003 travel trl. The propane side works. The elect side quit working. There is power to plug. The lights for auto and fridge inter. also work. The two fuses are good.
Unplug hydro plug to fridge. Remove cover on circuit board. Follow wires from heating element, to terminals on circuit board. ( probably J7 and J8 ) . With an AC volt meter or multimeter set to AC voltage, turn fridge on hydro, and leave door open on fridge so that it calls for cooling. To be sure it's calling for cool, try gas first, when it's starts, you know it's calling for cool, then switch to AC operation. Now test for voltage at the 2 terminals that the heating element were/are attached to. If you get 100-120 VAC, then replace the heating element. If not get back to me and I'll walk you through a couple more tests.
Jan 26, 2011 | Dometic RM2652 Refrigerator
Refrigerator for lp-gas and electri operation RM 2652 RM 2852 It will not light on gas or electric amylynnlpn@yahoo.com
SOLENOID VALVE Check the solenoid coil with a properly calibrated ohm meter. Remove the connector from the solenoid and measure the resistance across the terminals. The proper reading would be 49 ohms with tolerance range of ten percent. . . Next, hook up a manometer at the test port. Then check for DC volts at gas valve terminals while the unit is in trial-for-ianition. If DC volts are present and pressure is low, replace the valve. If DC volts are not present at the valve while the unit is in trial-for-ianition, verify that the wire at Plug 3, Terminal 2 on lower circuit board have DC volts v (9V or more)
IGNITER First verify proper voltage at the positive (+) and ground (-) terminals of the ignitor. The reading should be within one volt of incoming voltage at the main terminal block during trial-for-inanition Next, remove high voltage cable from igniter. The igniter should produce a sparking sound, during trial-for-inanition. If not, replace the igniter. The igniter installed on the refrigerators as original equipment is part number 2931132019 (RV Gas Model 679). This igniter is rated 50 MA. This igniter may also be used on any other model
Hope this helped
Appliance Wiz
Inanition: Proofing for ignition
Dec 27, 2010 | Dometic Refrigerators
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
You need to check your fuses on the fuse panel inside your coach. The frig will not operate on gas or electric without 12 volt power to the frig circuit board.
Feb 03, 2009 | Dometic RM2652 Refrigerator
Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Feb 01, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
716 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
