Question about HP Photosmart 8750 InkJet Printer
Photosmart 8750 carriage jammed error and skewed printing
In Publisher only, the printer skews the document until I get a carriage jammed error. It says to turn off printer to fix the problem. Paper feeds through fine, other documents print fine; I have reinstalled Publisher and printer driver and still get problem.
  • Anonymous May 03, 2009
    I have the same problem but with Phoroshop CS2 and only intemittently and only with photo-quality printing. The steps ourlined do work but the problem comes back after 6-10 sheets or so.
  • 679 Answers
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Posted on Feb 03, 2009
Km c253.. all colors skewed
Black image unit is the reference for registration might have a bad unit.
Jun 12, 2014 | Konica Minolta Office Equipment & Supplies
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
My hp photosmart c4780 won't align because is keeps saying that the alignment plot in the scanner is skewed
If you have had paper jam and not replaced the rear paper grey plastic retainer correctly or somehow it has become loosened the paper will twist on entry and the printing will be askew. Sometimes not loading paper. It will then also not align when replacing cartridge. Had this problem, took out the retainer that has two plastic points that should locate in the retaining holes and pushed it back. Paper jam, printouts and alignment was then fine. Took me months to figure out as it was printing, just not very straight
Jan 24, 2012 | Office Equipment & Supplies
HP photosmart 8750 - cartridge cradle jamb error
You need to check the encoder strip, the clear plastic behind the carriage, ink or grease will stop it from reading and give that error. Also ink buildup on the clean station will slow it's travel.
Dec 22, 2009 | HP Photosmart 8750 InkJet Printer
HOW DO YOU CORRECT A SKEWED COPY ON THE COPIER? HAVE CHANGED REGISTRATION ROLLERS, SKEW IS SAME FROM ALL TRAYS & BYPASS. TRIED ADJUSTING THE FOCAL LENGTH ON THE MIRRORS, AND STILL HAS ABOUT 1/8 INCH...
First you need to determine if it is optical skew or mechanical skew.
If the machine is used as a printer then do the computer prints come out skewed? If it is not connected to a PC then print out the counter list using UserTools/Counter. If that prints straight then you are dealing with optical skew. Ricoh's in general are bad about the left front corner of the machine drooping from someone pushing down on that corner. If you have optical skew try lifting up the left front corner of the copier and try making a copy. That might fix your problem.
If the UserTools/Couter print out is skewed then your back to a mechanical skew and there are numerous causes for that.
The optical skew is more likely so let's start there.
Nov 18, 2009 | Ricoh Aficio 1018D Copier
Carriage sticks. It shoots to the extreme left and the display reads" carriage Jammed"
This problem have when the encoder strip on printer is dirty.Try clean it with piece of cotton.If this not help may you need to clean the purge unit or all printer.
Oct 05, 2009 | HP Photosmart 8750 InkJet Printer
Canon mx700 5100 error
The 5100 error usually indicates a problem with the printer knowing where the printhead carriage unit is.
Chances are that when you cleared the jam you dislodged, damaged or otherwise skewed the little calibration strip at the back of the printer.
This strip is a clear bit of plastic that has lots of thin black lines on it and it's used by the printer to sense where it is.
If it's not that then it's most likely something jamming the printhead carriage somehow... ink soaked bits of paper are a favourite that I used to miss a lot.
Hope that helps.
Jan 30, 2009 | Canon MX700 Office All-In-One InkJet...
My HP photosmart c5280 keeps saying there is a carriage jam. what is this?
Lift the printer cover. undo the 2 screws (torx head). remove the right hand end of the printer casing.
You will see a blavck plastic moulding with a couple of gears (it controls the cartridge cleaning). This is the cause of your jam - it is out of sync. Turn the machine on and watch what happens with this moulding you will see what I mean by out of sync and it can just be gently pushed back into alignment. Once it is ok turn the unit off and then on again and your jam should be cleared. Put it back together again and print away.
Jan 07, 2009 | HP Photosmart C5280 Printer
Printing crooked, blurred, bad roller?
Sounds like when you pulled out the paper jam, you misaligned the print carriage. That would produce both the noises you hear and the print quality issues. HP.com has a few web pages on their site that might help. The first one deals with noisy print carriages. Unfortunately, it's not dedicated to just your product, but the steps should generally apply:
Resolving Noisy Print Carriage Issues
There's a separate web page available for troubleshooting crooked or skewed printouts:
Printed Text or images are Crooked or Skewed
If all else fails, unplug the power cord from the printer, wait 20 seconds or so, then plug it back in. That should restart the printer and make it go into a self test which may include a realignment procedure. Watch for any error messages on the display on the printer's control panel. Sometimes to realign, it prints out two test pages and instructs you to place the first printout on the scanner bed and then press Enter.
Go to the following web page and when it opens, scroll down to the section "Replacing the print cartridges", and find step 9 in that section for alignment instructions.
Replacing Print Cartridges
Good luck.
Oct 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Paper jam
is paper crinkled or is printer just giving a jam error/
Jan 15, 2008 | HP Photosmart 8750 InkJet Printer
HP Photosmart 8750 InkJet Printer Logo
420 people viewed this question
Seeker5211
Seeker5211
