Question about Polaroid FLM-4201 42 in. LCD Television
Picture too big
The picture on my Polaroid TLX04011C is too big.
Is there any way to reduce the sixe/ It was working fine.....(when watching a sporting event I got the whole picture on the screen....score at the bottom and all.) I moved the set to another room and after hooking up DVD and VCR the picture size is different. I must have done something to effect that but I have no idea what.....Help!!!
Joe Brad
  • 133 Answers
There will be a button on the remote that says aspect, or pic size, hit that button, untill you get the size you want, if you cant find the button, go into the menue, click the picture, or video section, and look for aspect racio, or pic size in there
Posted on Jan 10, 2009
SOURCE:
Picture to big
Try going into picture setting and reduce the zoom angle or if it's whilst you are watching Sky TV go into System Settings, Picture Settings and change the Aspect Ratio (ie. From 4:3 to 16:9 or visa versa)
Gadget
Feb 21, 2012 | Sansui 19 in. LCD TV
My polaroid TLA-04011c wont come on at all - it has a blue LED lit, indicating the set is on, but theres no picture whatsoever
First turn on and check with flashlight 2 in. from screen and see if there is a picture. If no picture then open back panel door by taking big black screw out of middle and 2 screw at bottom of panel and slide panel downward, pull off and unscrew metal plate and you should see bad caps in this set, this is what have to be replaced.
http://www.youtube.com/watch?v=EDylk9ezQtA
Dec 28, 2010 | Polaroid TLA-04011C 40 in. LCD TV
Pictures
The polaroid i830 does not have a good in built memory so u cannot take more than 2 pictures at a resolution of 8 mega pixels and 16mb is as good as no memory :-)
So, either you need to buy a SD card (I have 2 GB working perfectly fine with my i830) or reduce the resolution to VGA.
Steps:
1. Switch on the camera.
2. Push the button below 'M'.
3. You will find the option of resolution, select VGA.
You can now store upto 30 images.
Jul 27, 2009 | Polaroid i830 Digital Camera
I can't take more than 2 pictures and i need to find out why?
The polaroid i830 does not have a good built in memory so u cannot take more than 2 pictures at a resolution of 8 mega pixels.
Steps:
Mar 07, 2009 | Polaroid i830 Digital Camera
Polaroid TLX04011C picture is too big
There is a button on your remote control that controls the TV's zoom level. It is usually labeled WIDE MODE or ZOOM.
Jan 09, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No picture
if nobody will repair the tv, then your probably better off buy a new one. yours could have the bulbs blow, there could be something wrong with the board or the power supply. i don't recommend working on a tv because they are very easy to mess up and do even more damage. for your next tv, get a higher rated brand like samsung or sony. they tend to be more reliable and are easier to fix/find somebody to fix
Oct 21, 2008 | Polaroid FLM-4201 42 in. LCD Television
Crappy pictures
Describe wierd - this word means nothing. White flash images are over exposed- so reduce the ISO setting to a lowers number if the camera allows it. or Reduce power of the flash. The easiest way to do this is to put layers of tissue of the light reducing the intensity until you get it about right.
Jun 29, 2007 | Polaroid a300 Digital Camera
Polaroid LCD only shows green verticle lines?
your picture tube is not blown you are having problem in the color circuit there is an ic that controls that circuit,the tv is also having a vertical problem an ic also controls that circuit you will have to call a tech to repair your tv good luck
Apr 27, 2007 | Polaroid FLM-2011 Television
Polaroid FLM-4201 42 in. LCD Television Logo
132 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
