No picture using a HDMI to DVI cable. has sound on no matter what input tv is set to.
    Sniper:
  • 51 Answers
Which TV do you have???
Please tell me the options you have on your TV?
And In future please provide the problem with full details ok..
Posted on Jan 09, 2009
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
I use attached the pc on tv but i didi not here any sound please tell me sound pin cable attached the tv?
Hi sahazada pak,
As i know, TV set not support sound from PC input.
If you want here sound and still working with PC, you should use HDMI or DVI input from your PC out. HDMI has support image and sound in one cable. DVI only image without sound. if you use DVI , sound pc should connected to audio in.
Good luck.
Mar 22, 2011 | Samsung HLP6163W 61" Rear Projection...
What kind of cable if any can i use to make my wd52526 proj tv my pc comp monitor
Your projection TV has HDMI input so you would need to either run an HDMI-HDMI cable from an HDMI output on your computer or, more likely, a DVI-HDMI cable from the DVI output on teh computer to the HDMI input on the TV. If ycou can'T find a DVI-HDMI cable note that you can also buy DVI/HDMI adapters for one end of an HDMI-HDMI cable.
Note that DVI is HDMI minus the sound so if you do run DMI to HDMI you'll also need to route the sound to your TV or other amplifier.
If you only have a VGA output on your computer then you will not be able to easily run this to your TV as VGA is an anologue signal while DVI and HDMI are digital. To do this you'd need a converter.
Hope this helps. If so then please rate my advice.
Thanks
Sep 03, 2010 | Computers & Internet
How do i connect advent pc to philips hdtv. do i need to change settings?
well not really, you need to buy the proper cable depending on the inputs of your tv, it may have the standar VGA connection as the standar pc monitor.
DVI to VGA cable
DVI to DVI
HDMI to DVI
HDMI to HDMI
after you have the proper cable just plug it, and turn it off, disconnect the standar computer minitor and turn it back on. the computer will set the input signal from the tv by itself.
thats for the video, for the audio you need a different cable
3.5 mm to RCA (white and red cable)
3.5 mm to 3.5mm headphonejack cable
but if you are using the HDMI to HDMI you don't need a sound cable.
Oct 07, 2009 | Computers & Internet
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Hdmi/dvi
Here is the link to the user manual for the TV if you need it; http://www.haier.com/admin/en/product/upload/42EP24S-UM.pdf Check page 7 - The DVI input has next to it an audio input - DVI does not carry audio as HDMI does - you need to plug a seperate mono audio cable from your cable box to the TV at the DVI Audio input (top of page 12). The Audio needs to be in the one next to the DVI socket in order to work at the same time as the picture from the same "source" selection. Check page 18 "CATV Type" and make sure this is set to the correct one for your cable box Check page 21 that all the audio settings are logical and nothing is turned right down or muted. If none of this helps then please post back. What make and model is Your Cable box? Hope this helps :)
Aug 21, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
 Grubhead
Grubhead
