posted by WizOfOz on Jun 03, 2007
Purchased about 90 days ago. Radio works fine.
Used in small office at low volume primarily playing a CD disk.
CD quit working! The platter spins but the only sound is a repeating click from the speakers. The window shows two bars. The stop, pause or search buttons have no effect.
From what I see in this forum, this appears to be a common problem. Does "Emerson" have any response or solution?
Thanks
Best Solution
posted on Jun 04, 2007
Unfortanatly, this is why Emerson only warranties these for 90 days, but I have heard and recommend that you contact Emerson and tell them you did not think that their product would break down after a mear 90 days and a lot of times, they will send you a new one, if you bug them enough. There should be a contact number in the owners manual. If you do not have the owners manual, go to: http://www.emersonelectronics.ca/emerson... There is a contact link there. By the way, the problem you are having is a bad spindle motor or the laser optics are bad. Have you tried to clean the small laser lens off yet with a cotton swap and some good 90% or better alcohol? Good Luck
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Emerson PD6810 CD Boombox
Email this problem
Email this problem
Can you Help with these Boomboxes problems?
Can't I use it at work with...
Hello. I bought this product... Answer This...
Emerson PD6810 CD Boombox. I...
This is so stupid. The only... Answer This...
Repair Service
Find Boomboxe Repairman Near You:
