My Hp Laerjet 3015 is producing faded printouts. The whole page is faded. I've just replaced the toner but the problem persists. I've run the test from the HP Toolbox with no success. I've tested teh toner on another 3015 and it works fine. What could it be?
  • 495 Answers
Please try reinstalling your printer driver problem. It could be a driver software problem.
Posted on Jan 09, 2009
Very bed image on a paper
Print a couple of pages. As the printer is printing open the toner cover. Pull the toner cartridge out and look down at the paper. If the printing looks good the fuser probably needs replacing. Before doing that, have you checked the toner cartridge.
Mar 09, 2014 | HP LaserJet 3015 All-In-One Printer
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
I have 3 to 4 months old canon Imagerunner 2420L Printer *** photostat without duplex or any network /scanning facility.The Printout coming very faded, if I print on the backside of the printout . Eve
hi my immage scanner ir2420 display says front left side is open /close but i close evry thing steel the same falts so may be power suply problem how can i get diyagram of power supply plz
Nov 05, 2012 | Office Equipment & Supplies
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
My fax type hp laserjet 3015 display a very big line (blanket of line) on the right hand side of the paper, and the left hand side is normal. This problem is observed in the received fax and during...
The mark is not being produced from the toner cartridge or scan mirror. The line is being produced by the Drum unit. You need to replace it.
You can purchase one online or at you local stationery retailer.
Hope this helps.
Best regards,
Please vote if this helped
Nov 26, 2010 | Brother IntelliFAX 2800 Laser Fax
Dell 5110cn black toner
mag roller was jammed, forced a few rotations and it started to work
Feb 25, 2010 | Dell 5110cn Laser Printer
Hp 4300 laserjet. All printouts have a blank space
Remove the toner and wipe the small window that's above where the drum unit sits inside. That window gets covered with toner and makes light prints and blank areas.
Nov 18, 2009 | Office Equipment & Supplies
Copies come out dirty in spots, text is repeated as background.
I have to ask the obvious? have you removed the seal?
If yes, then it's likely just a defect, especially if it's a compatible / remanufactured cartridge -replace it.
Mar 27, 2009 | HP LaserJet 3015 All-In-One Printer
Fading black print
Is the toner orginal?
Try printing a test page and see how that comes out?
Try shaking the toner it might be stuck on one side.
Jan 06, 2009 | HP Color LaserJet 3500 Printer
Printout getting fainter magicolor 2300dl
Probably low toner if fading is on black only or a single color. To check levels, MENU (right arrow to Consumable Usage) MENU (right arrow to see each toner cartridge level) Readout may not be accurate, especially if you have changed or removed a toner cartridge.
Dec 10, 2008 | Konica Minolta magicolor 2300DL Laser...
110 people viewed this question
