Hello, Black rubbler like particles are being found in the washing basin of the machine and also in the discharge water... have you heard of this before? Thanks!!
    Guru:
  • 93 Answers
Sounds like some build up of soap and mildew over time between the inner and outer tub. Usually the case when we get this complaint.
Run some dishwasher magic through the washer. Works better than AFFRESH.
Good Luck!!
Posted on Jan 09, 2009
The bath water won't pump out. Seems like there's too much water left in the Saniplus itself to allow the bath inlet valve to open. Can this be adjusted? The toilet and wash basin are working OK.
This is a bit of a puzzle, if theres water in the Suniplus then the float valve will operate and the water will pumped out as it does for the toilet and wash basin.
I can only think that the bath discharge none return valve is stuck and needs removing and cleaning.
Hope that solves the problem.
Alllan
Mar 26, 2015 | Saniflo SaniPlus-Round SaniPlus Macerator...
How easy is it to take apart washing machine to clean out tub unit (the plastic one) I get awful smells in my laundry even after I've washed the clothes. I have let the machine sit with just
I assume you are talking about a top load machine. Usually the top of the washer will open up this is perhaps the trickiest part. Every manufacturer does it differently. When you get the top up or case off, there is a plastic ring that you can remove and clean out the outer tub. A refrigerator brush works well.
Sep 24, 2014 | Washing Machines
Order parts for 172165
Hello. If you are hoping to repair this and can see the crack that is causing the leak you can repair it with a marine grade epoxy. This can be found at Home Depot and most hardware stores. J.
Jul 10, 2010 | Black & Decker SpaceMaker ODC150 Coffee...
Washing machine stops in the middle of washing and then restarts. Machine fills and washes at the same time.
Could be that your discharge hose is causing the machine to syphon off water because there is no Air Break in the system
Test is to hook the hose into a basin and see if it does a full normal wash
Also could be problem with the pressure switch falsing due to a soap build up in the Air Bell on the side of the drum
Jul 08, 2009 | Kenmore Washing Machines
No pressure during wash cycle
check capacitor on motor. possibly not turning at correct speed
Jun 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
Jan 05, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
BLACK TAR-LIKE DEPOSITS INSIDE WASHER BASKET
THE DRUM INCLINE BOTH PLASTIC AND MEATAL SCRATCHING FROM DRUM CAUSE LIKE A CRAYON /SMALL PARTICLES , THE SUPPORT SPRING BESIDE THE DRUM ARE DETACHED NEED TO INSTALL SPRING / AVAILABLE IN APPLIANCES CENTER.
Jan 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Roper washing machine
It's direct drive. It may have a bad coupler. Did you see any black particles under washer? Also look for oil on floor and bottom of washer. Transmission can leak oil into clutch causing slow spin.
Nov 11, 2007 | Washing Machines
Discharge water smell
I found pouring baking soda down the drain once a month solves this problem...
Oct 20, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
150 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
