Question about Visioneer PrimaScan Colorado 2600u Flatbed Scanner
Installation I have a used scanner I don't know how to installI have it all pluged in ready to go !? I think
  • Diane Burkett Jun 03, 2007
    I downloaded the driver but cannot get the scanner going
  • Anonymous Aug 23, 2008
    the software ware is old i need a converter
  • 883 Answers
Search the web for "Visioneer 2600u" to locate a driver. then download it and run it.
Posted on Jun 03, 2007
  • Marty marty Jun 03, 2007
    try this. disconnect the scanner then uninstall the software then power down then restart then re-install software then restart if it requests that then plug in scanner
I'm having problem ,I don't know what really
I think you maybe infected by virus.Please do an online scan using NOD32s online scanner or using the antivirus present on your pc.
If no antivirus is able to sole the problem then you will have to reinstall the operating system.Using online scanner should sole the problem most likely.
Jun 06, 2011 | Computers & Internet
I lost my mercury flatbed scanner 2400cu+, i need to download the installation software. thanks for the help.
go to this site
close to the bottom you'll see the download link for different operating systems. They don't have support for vista but i think you can use windows xp with compatibility or windows 7.
hope this helps.
May 23, 2011 | Mustek Be@rPaw 2400CU Flatbed Scanner
Will not scan???
You need to check if the printer is properly connected to your pc and that the scanner driver was properly installed.
Connect the printer to a pc.
Assuming you are using windows operating system, go to control panel and double click the Scanners and Cameras icon. If you find the image of your printer then scanner driver was installed and that it is ready for use. If there is no printer in there, then the scanner driver was not installed and will need to run the cd installer that comes with your printer and install the driver for the scanner.
If by pressing the scan button on your printer and did not work, I do suggest you use the scan option on the control panel.
Let me know if I can help you further.
Feb 03, 2011 | HP PSC 2210xi All-In-One InkJet Printer
01 kia rio has bad rings in the # 3 cyl. i've been just changing the plugs and adding oil as needed but now the same old process happens missing, check engine light, changed all the plugs and wires still...
Rent a scanner, they present more information better that blinking lights. If the engine has a lot of miles, the timing belt is probably ready to fail. The better answer to your problems might be finding a good used engine in a wrecking yard rather than a rebuild of your engine to correct the oil use/plug fouling problem.
Oct 24, 2009 | 2001 Kia Rio
Scanner lamp its blinking
After disconnecting and later reconnecting the scanner no longer worked. The lamp started flashing 6 times with pause. The scanner was no longer recognised by the computer. I fixed it by disconnecting the usb and current plugs, and reconnecting the current plug while pushing the first en third buttons from the left on the front of the scanner.
Feb 12, 2009 | HP ScanJet 5300C Flatbed Scanner
How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Sep 30, 2008 | Symbol MC9090 Barcode Scanner
No drivers found
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
If it is not installed properly and working there should be a yellow triangle with an exclamation mark inside it next to the scanner name.
Whatever it says, right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready to use, re-install the scanner driver do not plug in the scanner yet!.
Once it has finished installing, re-connect the scanner USB lead.
Windows should install the drivers and tell you the scanner is ready to use.
Apr 24, 2008 | Canon CanoScan 4400f MultiFunction Color...
Visioneer PrimaScan Colorado 2600u Flatbed Scanner Logo
157 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
