Question about Tascam 2488 Portastudio Multitrack Recorder System
Guitar when i setup my tascaqm 2488 to do a song , i cant hear the guitar through the earphones . Whats up?
    Novelist:
  • 189 Answers
Things to check.
I'm assuming you are using the Hi-z input on the front of the 2488 to line-in your guitar. That input equates to the H input of the 2488 (you can use the front Hi-Z or the normal 1/4 inch input on the back as the H input). Therefore you need to turn up the H input trim pot to hear your guitar coming through. You should see the meters for the main stereo bus moving as signal is coming in. That means your signal is getting into the 2488 but it won't be assigned to any track until you assign input H to a track. Once you assign the input to a track and press the rec button for that track (to arm it for recording) you'll see the meters registering both on the stereo bus and for the track you have assigned.
If you've turned up the H input trim knob and still don't get any sound, insure that the volume knob on the guitar is turned up as well.
If that fails too I would try jiggling or using a different guitar wire.
Good luck.
bd.
Posted on Jan 12, 2009
Cant hear audio on tascam 2488i brand new to using it but i do understand how to record a track on my display screen i can see the audio i recorded but no sound what so ever i have my headphones plugged up...
hi
Tascam Digital recording is an effective solution for broadcast-quality home recordings. The Tascam 2488 is a user-friendly tool and useful for home recording situations, especially when writing songs or cutting demos. It even has bus compression and processing for your final mix to give it that "mastered" feel. There are other recorders as well.
Instructions
  1. Learn your gear. The Tascam 2488 DAW offers 24 discrete channels that can be recorded at up to 24-bit resolution. 16 tracks can be recorded simultaneously, via eight XLR balanced inputs and eith 1/4-inch unbalanced inputs. There are several high-quality built-in effects, such as reverb, delay, modulation, compression and a great tool for guitarists: amp and effect modeling. So you can simply plug directly into the console and get live amp tones.
  2. Record or program the rhythm tracks. Most Tascam products offer a large library of built-in drum loops to construct rhythm tracks, so you don't even need live drums just to get a song down. You can designate the tempo of your song from the transport located on the right side of the console; this is where you would use a variety of buttons to make edits, undo or redo and automate punch-ins
  3. Record your base rhythm instrument. Let's say a rhythm guitar. There is a dedicated guitar input located on the front of the console, and once you're plugged in you can use the aforementioned amp modeling features to dial up a sound.
  4. Record the remaining track or tracks. This could include bass, vocals, keyboards, horns or any other instrument. The process is always the same. Arm the track you wish to record on, hold in record and hit play, and the machine begins to record whatever you are playing. When you're done, hit stop. If you want to undo what you recorded, simply hit the undo button.
  5. Repeat these steps on any other instrument you want to record. Plug a microphone into one of the first eight XLR inputs, the first 4 of which have phantom power for studio condenser microphones, arm a track and record.
  • If you need to punch-in a section, you can automate it by dialing up the time in the song you wish to replace using the auto punch function. When you enable this and choose the time in the song you wish to record over, once you hit record and play it'll start the track a few seconds before where it begins the punch-in and it will only go into record when it reaches the designated time stamp.
Do not rush. Proper recording takes time and patience.
hopefully this can help
regards
Jun 11, 2011 | Tascam 2488 Portastudio Multitrack...
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Can i use my own electric guitar stomp box to record onto a tascam 2488 neo without miking an amp?
Yes, you should be able to go direct into the recording input if your guitar has a preamp in it and the 2488 may have adequate gain to even accept the input from a passive guitar.
Nov 30, 2010 | Tascam 2488mkii 24 Track Recording...
Sansa c250 audio problem
Playing some Mp3 players at full volume can cause this problem. Once the damage is done, there is no fix - sorry.
Apr 07, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
2488 Mk 1.
Hi Mike,
To reset the 2488 to factory defaults: Simultaneously press quick routing/shift/send/shutdown & turn on the unit.
The 'stop' button problem may require a look under the cover to see if the button is dirty or damaged under there. A good cleaning might do it. As for the 'no guitar out the monitors' issue, this sounds like it might have something to do with the setting of the monitor selector. Make sure it's set to 'stereo' and not effect loop or effect send or even muted. You might want to also make sure your monitor level pot is working properly.
Best of luck.
D.
Feb 20, 2008 | Tascam 2488 Portastudio Multitrack...
USB Export!?!?!?!?!?!?!?!AAAAHHHH
all i want is the dvd on the tascam 2488 cause the manual is a lot of work ,it leaves out the little things.
Jan 09, 2008 | Tascam 2488 Portastudio Multitrack...
N70 sound problem
simple solution,open your mobile cover and clean your earphone socket and make the two bruss colour pin which connect  your earphone with circuit little high so that it connect both the part each other,
Dec 08, 2007 | Nokia N70 Cellular Phone
Cant erase song
Is the song you are trying to erase the only song on the partition? If so, create a new song then try to erase.
Oct 10, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
121 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
