Question about Pioneer Televison & Video
Transport will not accept or load any discs
I own a Pioneer Elite DV-38A DVD player. I recently started experiencing tracking problems with discs of all types. This included skipping and locking up among other symptoms. Now the player will not accept a disc of any kind. When I insert a disc and press the close button the drawer closes, the display shows loading and then open, and then the disc is spat out. I have tried dozens of discs and the player now completely refuses to accept and load any disc I put into it. The player is approximately five to six years old and has seen relatively heavy use as the primary transport in my system. Does this in all likelihood indicate that the transport is pooched?If so would this be worth getting fixed? If so how much am I looking at paying,ballpark? Could it be something else more benign? I would surely appreciate any input you may have. Thanks
  • 905 Answers
Do you used a laser lens cleaning disc periodically cleaning the lens after every 8 hours of use or so ?
if not, and if the laser itself still is functioning , then manual cleaning of the lens with a drop of cleaning solution on a q-tip and then dry cleaning it with the other end of the q-tip , will get it going again
otherwise gears may need grease or worse, there is a problem with the laser , laser focus , or signal board , so then testing will need to be done to find out which has failed
Posted on Jan 09, 2009
How do I repair so I don't get "no disc" message?
Could be dirty or faulty laser, faulty decoder board or motor not spinning the disc.
Sep 06, 2014 | Pioneer Elite DV-46AV DVD Player
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
My player will no load. It just started "loading"
Make sure you are using a good DVD. Do not used burned DVDs. Make sure that the DVD you are using works in another player. If this is all being done and still no dice then there are a few other options:
-Has the DVD player been dropped, stored on its side, knocked around?
-Has there been a disc put into the player that had a label or something that would off center it, so once it started spinning with would wobble around?
Anything like this could have knocked the inside laser out of alignment, this would be a mechanical problem that could only be corrected by Pioneer or a technician.
Or, you can eBay is as used, purchase as-is.
Feb 28, 2011 | Pioneer DV-400V-S DVD Player
My dvd player keep on loading but it end up no
from direct experience, the problem is that the disk does not start spinning by itself - it will if you have the top off and give it a spin to start it ... I don't know what the ultimate solution is though.
Jul 04, 2010 | Pioneer DV-400V DVD Player
Pioneer muti-disk dv-c503 dvd/cd player carousel wont saty open
When i put a cd into the tray the door will close. It will say its loading but then the cd tray will reopen again not allowing the cd to play.
Nov 26, 2007 | Pioneer DV-C503 Multi-disc DVD Player
DVD WONT PLAY
same problem-put it in for repair -advised dvd tray is a one piece assy and it was faulty-requiring full assy rplcmnt @plus£150
nuff said=bought a new dvd
Feb 07, 2007 | Pioneer DV-525
Televison & Video Logo
546 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
