Question about Pentax Optio 330RS Digital Camera
Automatic retract of lens and camera shutdown after startup
Unexpectedly the lens of my Optio 330 retracts immediately after starting up the camera. Only the PENTAX tm display is briefly visible. When the lens is fully expanded a short vibration (less than 1/4 second) is heard after which the lens retracts and the camera switches off. This occurs in all modes except the viewing mode: the lens does not need to rollout in this mode and the camera behaves normally. Updating firmware did not solve the problem. Soft- and hard reset results in no change.
  • 2,985 Answers
Re: Automatic retract of lens and camera shutdown after...
A faulty switch it seems- Repair shop job unless you have some warranty left. Check Pentax technical help team
Posted on Jun 03, 2007
0 characters
3 Points
Lens on Optio S5z will not retract. When turned
Please view my FixYa tip on this subject for a complete walkthrough of the potential causes and solutions.
Many thanks for using FixYa.
Dec 18, 2009 | Pentax Optio S5z Digital Camera
Lens stuck in
You'll need to either take this to a qualified repair shop or replace. Depending on the cost of the repair (Which I would guess as significant) it will more than likely be more economical to replace.
Jul 08, 2009 | Pentax Optio 550 Digital Camera
Shutdown sometimes fails - Lens retracts then immediately extends again
I am having the same problem with my camera. I have to take the batteries out to get it to shut down. I also cannot view my photos on the camera, when I try to turn it to view, it goes to shoot mode.
Aug 01, 2008 | Canon PowerShot S3 IS Digital Camera
Pentax Optio M20
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Optio 330 rs
It sounds as if the battery is very low on power. Try charging it up.
Jan 13, 2008 | Pentax Optio 330RS Digital Camera
Pentax Optio M20
When the camera is turned on, the lens extends, makes a slight buzzing sound and then retracts and the camera turns off.
Jan 01, 2008 | Pentax Optio S Digital Camera
Lens does not retract
I'm looking for a solution to this too. The repair is going to cost more than the camera did. SUCKS!!!
Dec 02, 2007 | Pentax Optio M30 Digital Camera
Shutter problem
I have an Optio 330 too. Have had it since Feb 2002 (second owner) and taken over 5000 shots. I experienced something similar earlier this year: when i pressed the "on" button, the lens would extend, then there would be a jarring noise, the lens retracts, and the camera switches off. The camera couldnt work at all. I almost sent it in for servicing after a few days. However, I gave its base a firm bang squarely onto a thick floor rug. That solved it! The problem recurred one month later, i did the same thing, and it solved the problem again. Overall, the Optio is quite hardy, though it can get cranky with age. Hope it works for you.
Sep 08, 2005 | Pentax Optio 330 Digital Camera
Optio s5i Lens Stuck Problem
You can try removing the battery and leaving out overnight then putting it back and charging it up then try the power. This has worked for some people but not all.
Sep 08, 2005 | Pentax Optio S5i Digital Camera
Pentax Optio 330RS Digital Camera Logo
238 people viewed this question
Top Pentax Digital Cameras Experts
Are you a Pentax Digital Camera Expert? Answer questions, earn points and help others
