Load noise during spin cycle also metal wire sticking out of drum inside washer. This is a Kenmore elite he3 5 years old
    New Friend:
I think it might be fixable but u should go to O' Riley's Auto Parts and ask someone there.
Posted on Nov 23, 2012
SOURCE:
dididsaythat
  • 291 Answers
SOURCE: kenmore elite washer 26922
I would take body of washer find out where noise coeing from.. got 2 screws in each side of head, flip head up and take clamps off .. pull whole body off washer run thu cycle and see if ya can locate the noise.. sometimes water pumps get something in them that well make weird noises.. but are in all cycles.
Posted on Sep 07, 2007
  • 40 Answers
SOURCE: Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Posted on Mar 10, 2009
  • 249 Answers
SOURCE: Loud Noise during spin cycle
drum bearings are gone,it would cost too much to repair,the drum shaft would to be repalced as well.Sorry
Posted on Dec 17, 2007
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
SOURCE: Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Posted on Apr 06, 2009
I have a Kenmore HT4 front washer and it washer is making a loud noise when it is in the spinning cycle. It sounds like the inside cycle is hitting up against something. It seem to wash okay and we...
There is only two things that I can think of 1: The bearings are going or 2: something has got under the door seal and is in between the metal drum and the plastic cover (around the drum). Could be something like a coin or even a bra wire.
Jul 28, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Kenmore elite clicking noise
This may sound basic and I'm not trying to be a wise guy, but is there any metal objects in the washer, like a pair of jeans with metal buttons? This could be the clicking that you hear.
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Heavy Duty Washer
Whirlpool is still made in USA, I think. Avoid electronic timers and geegaws you don't need.
Dec 22, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
55 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
