Question about HTC Touch Diamond Smartphone
I am having a problem with my phone not sincing with pc. I am using Active sync 4.5? error code i find is 0x80004005. please help
    Problem Solver:
  • 9 Answers
I HAVE FROM BELL MOBILITY IN CANADA THERE JUNK TAKE RECEIT AND PHONE THEN ASK FOR REPAIR ORDER SHOULD GET YOU A NEW PHONE
Posted on Jan 09, 2009
Customer help line
Here are the steps:
1. Make the partnership between the phone and the pc with the cable first and let it sync once.
2. Unplug the cable, turn on the bluetooth and make the pc and phone connect through bluetooth and save the device in the device list so it can connect everytime you want to sync without adding the device again.
3. Once they are connected to each other run active sync (with bluetooth still active) and press Menu-Connect via bluetooth. Here's the tricky part, it wont always connect. You have to do this a couple of times until you get a connection. For me its like 4-5 times and i get connected.
Thats it.
May 20, 2014 | Cell Phones
Microsoft Activesync not working properly
Have you tried synchronizing it to a new outlook profile?
Jun 17, 2008 | Microsoft Computers & Internet
Error code 0x80004005
Dear Expert Team, I want to connect my Bluetooth Wireless Head Phone to System the error code is mentioned below
ERROR CODE 0*80004005 (Model No BH-503)
so,How can i connect please give me a solution.Please email me tirumalasettymouli@gmail.com
Aug 05, 2012 | Nokia BH-214 Bluetooth Stereo Headset
Serious Issue re ActiveSync 4.5, HTC Touch, WM6
pls tell me what do u want to do with active sync bcoz this small piece of software gives lot of trouble in winxp , vista WMDC works ok , i know u are frustrated with microsoft support infact support one some issues does not even exist at all , this problem is not from ur PDA it is from this malfunc software that is called active sync , pls let me know if u use active sync to backup ur contacts then u can do it with SPB backup better than active sync without errors u can losd it it to ur pda and can make backups from ur pda not pc dependent at all
pls let me know abt ur usage of this software
pls rate me if u find me helping
Mar 09, 2009 | Computers & Internet
by what i have seen when i have that problem i have deleted the partnership from active sync and then recreated the partnership, be sure that you have all your info backed up though because it will wipe it all off. That should help if not let me know
Mar 02, 2009 | HTC Touch HD Smartphone
Ipaq 4700 active sync problems
i can try to help you , first are you using xp or vista ? and which version of active sync ? i found that after upgrading to active sync v4.5 my ipaq 4700 refused to sync , i have xp home , so by trial and error i learned several things , i tryed my usb cable in every usb slot i had , only to find some usb ports are more friendly to certain devices , for a lack of better terms , i deleted all partnerships in active sync , found that i needed to make sure active sync is not running on ipaq , go to settings / memory / running programs on the ipaq , stop all running programs , turn the ipaq off , then on the pc made sure firewall not locked , plug usb cable into pc , i leave mine in a port permanently , plug into the ipaq , it automatically turns the ipaq on , then i see 2 icons in pc system subtray start blinking , at that point i know sync is going to work , then active sync icon starts turning , lit up in green , and asks do you want to create a partnership , yes , follow prompts , and thats what has been working for me , now if i was to put the usb cable into a different port , no doubt it would give me grief , and the same thing with my phone and active sync , make sure active sync is not running on the device , sometimes i have to reset the unit , ipaq or phone , make sure unit is turned off them make the connection , give it a try .
Jan 02, 2009 | Computers & Internet
Sansung i780 to be used as a USB modem
(I) 1)First pair the PC and your phone of course 2)After pairing, meaning the phone and the pc sees each other, go to your phone and look for the icon "internet sharing". 3)Choose bluetooth pan as you pc connection then press connect. So now your phone is on data connection via gprs, 3g or 3g+ 4) Then go to your pc now and go to My bluetooth places search for Network Access Point and enable it. It will turn green with arrows, meaning it has established a connection.TADA! Now you have internet connection using your i780s
(II) Do you have in your programs or settings a icon called Internet Sharing?
If so please connect to active sync first and then select the internet sharing icon.
Active sync will disconnect and your laptop will start using your phone as the modem.
Wuth
Jul 01, 2008 | Cell Phones
Try this, I read it on a microsoft.com forum.
Disconnect the device from the PC.
Open Activesync on the device.
Open the "Menu".
Click "Options"
Uncheck "E-mail" from Data you want to Sync.
Click "Done"
and re-sync devise to PC.
Once I did that, my contacts and all my appointments sync'd.
Hope that helps...
It seems tons of people have had this annoying issue.
Jan 19, 2008 | HTC Touch P3450 Smartphone
Jornada 568 Sync Problems
All you have to do: Select Device Manager, select "Universal Serial Bus controlled". Re-install the USB driver from Active-Sync CD. That's it.
Sep 12, 2005 | HP Jornada 568 Pocket PC
Problems with installing Active Sync on Windows xp.
Do you use companion CD for Active sync installation? Can you please tell me which driver is necessary to have? Is there any error message and what is content of this message? It can also be that Active Sync is already installed! Please check at Add and remove Software in Control panel! Otherwise go to www.microsoft.com and download a current version of active sync
Sep 11, 2005 | Toshiba e400 Pocket PC
HTC Touch Diamond Smartphone Logo
67 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
