Question about Durabrand 5.1 Surround Sound Computer Speakers
Hi i got a HT-3918 and i'm having problems turning on. i just don't see any flashing light and i don't hear anything i've checked all already.
Hey I've had my Logitech z506 speakers for a few
I don't know for certain but, this is usually a sign of the overload circuit in operation. Speakers are not designed to be used on full volume constantly. Next time this happens try and turn them off for a couple of minutes, when you turn them on again try with the volume lower than when you turned them off. If you are regularly using them at full volume, then maybe it is time to invest in a more powerful set. Buy them by their RMS power output, NOT by their PMPO (peak mean power output) this is already an inflated figure and is usually about 4 times the real power output. I hope this helps.
Jan 21, 2013 | Audio Players & Recorders
I wear headphones at work and don't always hear my phone is there a way to connect it to my computer so it will interrupt the music?
Not that i know of BUT you can get a hearing impaired device that connect to your phone that has a loud ringer and or flashing light.
Oct 25, 2012 | Samsung 10-Falcon Idcs 18d Telephones...
Micro innovation speaker model# MM610D will not turn on
This Is A Huge Problem, Why Don't You Try Reconnecting The
Wires To The System And Run A Reset On It.
Good Luck,
Kevin
Aug 24, 2012 | Micro Innovations MM600D Computer Speakers
I've got a dim blue flashing light from my subwoofer with Soundsticks usb. Is this a poweradapter problem or an electronic problem?
Hello
It is with its power transformer problem itself. There is a protection fuse inside, which will blow out, of any direct short circuit occurs inside the unit. when the fuse blows out, a blue light, such you describes here can be seen from it, as its body is transparent.
But, before replacing this fuse, you have to find out the exact reason for its blow out, before replacing it with an other similar one. OK.
Feb 10, 2012 | Harman Kardon SoundSticks Computer...
My daughter unplugged a speaker. I plugged it back in and now I don't get sound. I've checked to see if they are working properly and they are. Any solutions?
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jul 13, 2011 | Logitech X-530 Computer Speakers
Can you help me?
Hi
Check your speaker connections and volume adjustment knob.
If there is a power light indicator of your speaker make sure it is working so that you will know that there is power passing into your speaker.
Hope is helps..Thanks for using Fixya.
Apr 01, 2010 | AOpen MS-915 Computer Speakers
When i go to play songs on my computer i cant hear anything. is it my speackers or the computer?
Try installing and configuring a media player such as windows media player. If you already have a media player install, check the configuration and file extensions.
Jul 19, 2009 | Audio Players & Recorders
My right speaker from my z-2300 stop working.
sounds like a loose connection somewhere inside that particular speaker. You could open it up to check for a loose or separated solder joint. The safe option would be to return to place of purchase and exchange for a new set.
Apr 14, 2008 | Logitech Z-2300 Computer Speakers
Picky speakers
uninstall then reinstall adobe flash player. see if it works.
Feb 14, 2008 | Dell A215 Computer Speakers
Speaker problem
check for the connections! unplug and plug then back! test it! if it still have the same problem then it might be at the circuitry already! maybe some electronic components were busted or malfunctioned already!
if you happen to open it! check for bulged capacitors or loose connected components on the circuity!
Nov 15, 2007 | Altec Lansing ATP 3W Computer Speakers
Durabrand 5.1 Surround Sound Computer Speakers Logo
296 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Geoff
Brian Sullivan
Brian Sullivan
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
