Question about Little Giant Opwg 71 71 Gpm Out of Pond Pump, No Power Cord
PUMP RUNS BUT DOES NOT **** UP WATER
2500 GPH EXTERNAL KOI POND WATER FALL PUMP RUNS BUT DOES NOT TAKE IN WATER FROM POND CONNECTED BY ABS PIPES.
    Problem Solver:
  • 9 Answers
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Posted on Jan 22, 2009
How do i prime my pond filter and pump
Consult your owner manual to achieve proper priming.
Apr 16, 2014 | Max Flo Waterfall Pump 2900 Gph
Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Apr 17, 2010 | Tsurumi Pump s Submersible Trash Pump -...
I have a AquaScape 4500 GPH Pump it has worked fine. Today I spent all day cleaning out my pond. All I did was lift the pump out of the pond and spray the muck off it. After completly cleaning the pond and...
Where the wire goes into the pump there is a o ring thatis probably leaking and any sort of water the motor might be getting is tripping the breaker. You probably have it plugged into a gfi and it sense very low amounts of water, and trips, You can determine by plugging it into a regular outlet and it should work. But definently fix the oring at the point of entry on the pump
Apr 17, 2010 | RTO AquaScape 4500 GPH Pump
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
I have a 4300 GPH Pump It got left on out side of
Most likeluy it overheated wile running outside of the water. It neds the water for cooling.
You might need to buy a new one
Sep 23, 2009 | Sunterra 3000 GPH Pond Pump 203000
I've had this pump for 1 year and its worked fine.
yes, it's probably on a GFCI circuit and it will need to be dried out and maybe sealed up good to prevent 'current leakage'
Aug 01, 2009 | Garden
The motor runs, but not take in the water
Check the strainer at the pond. Prime the pump and see if it pumps anything.
Apr 27, 2009 | Garden
Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Apr 12, 2009 | Garden
Savio waterfall pump not pumping strong enough
This might be like the problem I experienced ... the 3600 gph SAVIO pump I have needs to be primed to get rid of the air in the pipe.
Apr 06, 2009 | Savio Water Master Solids Handling Pond...
Little Giant Opwg 71 71 Gpm Out of Pond Pump, No Power Cord  Logo
401 people viewed this question
Top Little Giant Garden Experts
J.D. Browning
J.D. Browning
Jim Goldsmith
Jim Goldsmith
Mike Squire
Are you a Little Giant Garden Expert? Answer questions, earn points and help others
