Question about Samsung SF-335T Plain Paper Inkjet Fax
Download waiting ?
The display shows 'download waiting' and the machine wont do anything - not a beep or a light or a dial tone? - I would be very grateful for any input - has the chip lost its program?
Power the unit off, wait 30 secs, hold down the STOP\Cancel button whilst inserting power. Wait for Sys Init and Clearing msgs to cycle and release button. As suggested by Samsung tech support, don't know if it's a permanent fix....
Posted on Aug 13, 2007
  • 328 Answers
Try Samsung,s site for a firmware update.
Posted on Aug 10, 2007
WHEN I SEND FAX THER IS NO ANSWER
Dear
Connect a telephone set to the extension of the fax machine port where it is marked as EXT.
put the document on ADF or platen glass.
press OHD/Spk Key (get the dial tone)
Dial the required fax no.(get the ring back tone-then RX tone(some kind of beep tone)
Press START.
Display shows sending (if not display may shows 1-sending,2-receiving, then press 1. for sending)
Take the hand set of the telephone hear the noise continuous.
If there is no noise, There some problem with hardware, misht be LIU card, main PBA or both. And you need the assistance of a trained service engineer.
Thanks.
Feb 25, 2015 | Samsung Office Equipment & Supplies
After dialing and scanning to send fax the machine says wait and then goes to print report and starts printing
Dear
Pl. check the tel.line, test for voice communication,if its ok and without any noise, there may be problem with fax communication line(internal), this may be tested by connecting a parallel telephone set and hearing the beep tones while sending the fax.(put the document in the ADF dial any one no. just to cut dial tone press START, ) If no beep tones in regular interval heard. its due to LIU card fault(mostly). You need to replace or repair the card.
Thanks.
Feb 24, 2015 | Canon FAXPHONE B740 Plain Paper Bubblejet
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
My panasonic kx-fl501 fax message says please wait and the keys don't work
I realize this thread is old, but I just encountered the same problem with my Panasonic KX-FL501. Pressing #9000* does not work, as none of the key pads are responding. When I lift the receiver I get a tone. But the keys don't respond when I dial. Display shows "please wait"..... I've been waiting for hours.
Feb 08, 2012 | Panasonic KX-FL501 Plain Paper Laser Fax
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
The green light is on to show that the machine is ready to be fax, but i don't hear anything when i try dial the fax humber
green light only means the machine is on with no malfunction. You need to check that you hear a dial tone- make sure the phone line is connected from both ends. Try to connect a regular phone to the same line and see if you get a dial tone.
Jul 14, 2009 | HP J3680 Officejet All In One Printer
Washing machine will not start wash - just beeps - key on display
Press and hold the Rinse Plus button and wait for the washer to start emitting a tone.
Whilst you are pressing and holding the Rinse Plus button, the tone increases in volume from low to high and then it briefly goes silent, before it starts over agian.
If you release the Rinse Plus button immediately the tone goes silent, then this will turn off the beeping.
If you don't release the Rinse Plus button in time, just continue to press and hold the button and the tone will cycle around again from low to high to silent.
Hope that helps.
Dec 07, 2008 | Audiovox Bosch 718 World Cellular Phone
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Samsung SF-335T Plain Paper Inkjet Fax Logo
239 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
