Question about V, Inc. Vizio L13 LCD Television
Picture appears to be going out
The color is all washed out and appears the brightness is turned all the way up. I tried changing cables and it doesn't matter whether it is on TV, DVD, or any other mode. How do I get the picture back?
  • David Trimbur Jun 03, 2007
    made sure settings were as you said above but no change. Picture is faded as if it is going out
  • Anonymous Feb 15, 2009
    Yep, same problem. Picture appears to have nearly disappeared. I get washed out color and grey/black clouding.
    Novelist:
  • 192 Answers
Make sure the brightness is set at about 45% of it's max setting and the contrast or picture control is set at about 90% or almost all the way up. The rest of the picture settings should be: Color about 45% Tint should be at 50% Sharpness should also be about 50%. These settings are my default settings when I am a customers home. The set should look good at this point. If not then the main PCB is suspected of being the problem. Hope this helps.
Posted on Jun 03, 2007
SOURCE:
Auto-dimming problem
It depends of the set--may have a light sensor built in and if so when light in the room changes the brightness on the TV and contrast will vary.
May 30, 2012 | Vizio Televison & Video
My philips dvp3560 will only playback in black and white
Check the TV System menu:
[TV System]
Change this setting if the video does not appear
correctly. By default, this setting matches the most
common setting for TVs in your country.
• [PAL] - For a PAL-system TV. (European TVs)
• [Multi] - For TV that is compatible with both
PAL and NTSC.
• [NTSC] - For an NTSC-system TV. (American TVs)
Also try:
[Picture Setting]
Select a predefined set of picture color settings or
customize the personal setting.
• [Standard] - Original color setting.
• [Bright] - Vibrant color setting.
• [Soft] - Warm color setting.
• [Personal] - Customize the color setting. Set
the level of brightness, contrast, tint and color
saturation, then press OK
Mar 05, 2011 | Philips DVP3560 DVD Player
Well i don,t know what i did but there appeared light color of light black back ground i can not remove this background picture how do i shut it of thank you.
U turn to another channel,now it look like u have a picture of a shadow behind it?Yes,than u have freeze a picture on the tv for a long,might have a tv screen burn in.Tries go into tv menu go to colors setting.Tries contrast setting all the way up to maximum.Tries colors a third of a setting.The brightness half of it setting.Should or might help to solved this problems.
Dec 06, 2010 | JVC AV-32D305 32" TV
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
Color
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The Contrast and Brightness on tv appears to be dark.
If this is a CRT-based TV and it's been played most of the time, you may have a bad picture tube, especially if strong red colors bleed to the right. CRT's dim with use, unlike LCD or plasma. But it could also be trouble in the video circuits - none of this falls into the DIY category, unfortunately. High voltage involved, unless you're comfortable around it and want to try turning up the screen controls inside the TV. If you do, let me know - but "no response at all" from the external adjustments points to a more serious problem.
Dec 10, 2008 | Toshiba 36AF41 36" TV
No color
does the tv use Svideo as an input from whatever device you're using on the main screen? if so , try changing out the cable for a new one, svideo carries 2 signals, color and brightness (ie color and black signals) if your cable is bad or broken, you may only be getting one of those signals ( the black one) try a new cable if it's s-video. if it's not, get back to us.
Sep 13, 2007 | Hitachi 50SBX78B 50" Rear Projection...
No contrast
first turn your color all way off or down.try turning your contrast way down as far as it will go you should see a darker picture. now bring up the brightness to a point half way. bring the contrast up to see grays and whites and blacks...adjust brightness more if need be. now you should see a nice black and white picture. no bring your color up last ...not saturate but to your liking. if you stilll got problems i bet your video out transistor is shorted....meaning shop work.
Aug 31, 2007 | Panasonic PT-51HX41 51" Rear Projection...
V, Inc. Vizio L13 LCD Television Logo
189 people viewed this question
Top V, Inc. Televison & Video Experts
Tony Nguyen
Tony Nguyen
rostit
Are you a V, Inc. Televison and Video Expert? Answer questions, earn points and help others
