Question about Epson Stylus CX4600 All-In-One InkJet Printer
Changed all ink cartridges, now only black and blue print
It has been about 1 1/2 years since i've used my Epson cx4600 printer and now that I have exchanged my ink cartridges only the black and blue work and barely. I'm am sure that these problems are happening due to the long amount of time it sat with no ink, but I am unsure how to solve my problem. I have done print test after print test and I have charged the ink cartridges many time's in hope's it might losen up any dried up ink. Still nothing. If there is anyone who can help me that would be great!
    Problem Solver:
  • 4 Answers
Sounds like your printhead is clogged. Since it isn't removable on this printer the following is a last ditch somewhat messy possible fix.
Here is the procedure that got my CX4600 printer working again:
Symptoms: head cleaning made the test pattern get worse instead of better, until I got no test pattern at all.
1. Unscrew the service panel door on the back of the unit to expose the waste tubes.
2. The direction of flow is "down from the TOP tube, into the plastic elbow, out to the RIGHT tube that goes to the waste repository".
3. Disconnect the plastic elbow from both tubes.
4. Clean the elbow using a paper clip and peroxide until it is completely unclogged and clean.
5. Get a waste receptacle, such as a small cup or something to catch the ink, and place it under the TOP tube. You will probably have to aim the tube with your fingers or a pair of pliers into the cup. The waste is going to spray out, possibly spatter if the waste has become hardened in the tube, so make sure you're doing this somewhere that you can clean up easily.
6. With the waste tube aimed at the cup, hold down the "ink" button on the printer until the cleaning sequence starts. The sequence will take about 20 seconds and blow the tube out in spurts.
7. If stubborn, you can loosen the junk in the tube using some peroxide - it doesn't take more than a drop from the end of a q-tip to start eating away... give it a few seconds to work itself upwards into the tube. Massage the peroxide up the tube with your fingers for more effectiveness.
8. Run the cleaning cycle one or two times to make sure that there is either air or nice wet ink coming out, but no more solid waste.
9. Reassemble
10. Connect CX4600 back to your printer, and print a test pattern... perhaps one more cleaning... should be fine.
Also see this website:
http://www.fixyourownprinter.com/forums/inkjet/23861
Posted on Jan 09, 2009
Head cleaning not working
Doesnt sound like you Used Genuine Cartirdges?
Did you use Epson Genuine Cartridges? ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE BETTER IF YOU DISABLE THE INK MONITOR.
This is the only advice I can give you.
The next step would be to disassemble the Epson, and clean the Pads/Heads. Click on link below.:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 04, 2010 | Epson Stylus Color 740 InkJet Printer
My prints are all coming out faded and light- i;ve tried to clean the nozzles and head adjust, the cartiges are all new. Any advice?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Feb 09, 2010 | Epson Stylus Photo R1800 InkJet Printer
Hi, when printing the page is full black. After head clean, nozzle check etc still black & nozzle check prints two x dark lines. I changed ink cartridges but no improvement. Thanks, Roger
Feb 06, 2010 | Epson Stylus Photo 1290 InkJet Printer
I changed my ink cartridge but the printer is not working
Did you use Genuine Cartridges? Brother Genuine Cartridges????
Feb 05, 2010 | Brother MFC-640CW All-In-One InkJet...
My brother printer not working well
Are you using Genunine Cartridges!!!!
Feb 03, 2010 | Brother MFC-5840CN All-In-One InkJet...
After every line of black text there is a light blue line.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Feb 01, 2010 | Epson Stylus CX3200 All-In-One InkJet...
I just changed cartridges and the ink isn't flowing smoothly and the sentances are in black and blue ink. How do I reset?
Jan 31, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I changed the black ink cartridge, and now it prints, but the paper is blank.
Epson Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a chip, that will detect if it is Generic or Genunie. When using Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
Jan 23, 2010 | Epson Stylus CX6000 All-In-One InkJet...
Epson Tylus CX4600 ink light
If any ink cartridge is empty, you won't be able to print until you replace the empty cartridge. Leave any empty cartridge installed in the device until you have obtained a replacement.
The print heads will clog up in a week or two. So you also won't be able to print until you clean the print heads.
This is a utility to manage your ink. Gives an accurate count of how many ink shots are left in each cartridge. The printer told me I need a new magenta but this program says I have 13% left. It also has separate routines for cleaning the black and color (unfortunately not individual cartridges)
http://www.ssclg.com/epsone.shtml
May 18, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Epson Stylus CX4600 All-In-One InkJet Printer Logo
173 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
