Steel Series SteelSeries 7H Headset - Stereo Over-the-head - Binaural - Ear-cup - Mini-phone - Black (61050) PC Desktop Logo
Posted on Nov 23, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Headphones Sound only comes out of the left side of the headphones. I made sure to plug in the jack all the way, and tried to use it on multiple devices. They are brand new, I just got them out of the case.
Aries
Level 2:
Sergeant:
  • Expert 206 Answers
  • Posted on Nov 27, 2012
 Aries
Expert
Level 2:
Sergeant:
Answers
206
Questions
Helped
53372
Points
891
Hi
Try them in another device to eliminate a faulty jack, if they still dont work the head phone may be faulty, return to seller and ask for a refund or replacement.
But also try a different head set in the jack to see if the jacks working properly.
Cheers
Matthew
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 15, 2014
Matthew
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
593
Points
I should have mentioned that I plugged them into the motherboard at the back. However, this was just a troubleshooting step to make sure it was'nt the provided usb sound card at fault.
When I tested the headphones on my housemates pc, I used the usb sound card and it worked fine.
  • Matthew
    Matthew Aug 15, 2014
    sorry i didnt meant to post that here, im new to fixya :*(
I plugged in my headphones and it only plays sounds on one side.
there is a head phone jack in the front and the back. have you tried them both?
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Headphones for a laptop not working
click on Sound
select that!!
hope this helps
1helpful
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
1helpful
2answers
Computer isnt detecting i have headphones when plugged in
you need to plug the headphone jack in the right port. it is usually in the innermost left part. Also, make sure your sound card drivers are installed properly.
Fixed broken headphones but sound quality has plummeted
 it sounds as if the wires are wired wrong . yes it is best to solder the wires.all jacks are the same,yours will be stereo i believe. is the braid attached to the earth point, the two other wires attach to the centre of the plug and the other terminal point. these are right and left.
Only hearing sound out of left side of headphones
i think the problem is in the jack of your sound blaster. since you have already tried different headphones and the problem still persist, and when you use speakers it works fine. i conclude it is the jack of your sound blaster card.
New headphones
Try plugging them into the jacks on the back of the PC case. Make sure you connect the right connector to the right jack. If this works, then there is a problem with the front jacks. Sometimes they are left unattached when the PC is assembled.
Also, check in control panel under sounds and make sure you have a sound scheme selected. If it says no sound scheme, select one, the click NO if Save sound scheme prompt comes up.
2helpful
Right speaker malfunction
try blowing the headphone jack hole. One hard puff should do the job
Top Steel Series Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Steel Series Computer and Internet Expert? Answer questions, earn points and help others
