Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Get a Professional
Find a Solution
Most Common Problems for:
Engine stalls
waynegiroux on Jan 09, 2009
idles great but stall when you but on break or throttle down during a cut
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 10, 2009
Very Helpful)
Gilesf
Rank: Wiz
Rating: 87%, 27 votes
Sound like the clutch is not disengging. The springs in it are likely week. Take note as to weather the chain stops when it is idleing. If it seem to idle at a reasonable speed and the chain does not stop turning, the clutch is most likely the problem. This problem can be caused by trying to work the saw without the throttle wide open. When the clutch slips it creates heat wich will over heat, and weeken the springs used to disengage the clutch. It is also possible that it was defective when new.
Was this helpful?
Yes
No
Related Problems
how do I do a basic tuning for a poulan pro 295? Just above...
I AM UNABLE TO GET THE FUEL CAP TO SCREW DOWN TIGHT ENOUGH...
overheating why? can only run four an hour at most then it...
Can you Help with these Chain Saw problems?
need side cover over chain guard
Solve
need side cover over chain guard where tenson screw is independant cover from rest of cover - cover... (More)
rope will not retract
Solve
I have a 18 inch poulan wildthing chainsaw and it's rather new with little use. The rope got stuck... (More)
my recoil inside the pullstart
Solve
I'm not sure how to put it back in, someone else pulled it out.
Reattaching the recoil spring to the...
Solve
A friend's chainsaw starter cord stopped retracting. He took the winder cover off and apart. He... (More)
Chain brake Assembly
Solve
I need to know how the spring fits inside the brake handle so I can put it back together.
Sponsored Links
Describe your Tools problem:
Top Chain Saw Experts
Rank: Guru Guru
Solutions: 702
Experience: Certified Master ASE Car and Truck Mechanic Certified AC mechanic Cert. AWS welder cert. Electrician
Ask Me
Find more Chain Saw Experts
Top Garden & Power Tool Repair
(800) 383-6584
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
