Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
When i connect the tv to my computer it tell me the signal is compatible
  • 362 Answers
Go to the Sharp website and download the driver. That should fix it, assuming you meant not-compatible.
Let me know if that helps.
lone99star
Posted on Jan 09, 2009
I have a Philips LCD 1080P 55" TV and it is showing a black screen with "Please change computer's screen resolution" on the bottom. I don't have a computer linked to this TV...
It does not matter that you do not have a computer hooked up or not what it is telling you in a scripted message where a computer might be used for that connection is that you have a setting wrong in the display section of the flat panel that is not compatible with the input signal. Find out what kind of input signal; you are supplying to the display and then set your display setting if they go that high to that display mode and the unit should give you a picture.
Aug 10, 2012 | Philips Televison & Video
Magnavox LCD tv external speaker
Hello
The jack you describes here "Digital Ouput Device To" means, you can connect these jacks to the output of a digital device, such as DVD or so. It is meant for to get signal into the TV, not ot out.
HDMI [High Definition Multimedia Interface] is a type of connection, which the TV an be connected to any HDMI device from outside. Both the above said are, signal in to TV connections. Not out.
If you want to connect this TV to any amp or any other external audio devices; look for any audio out option is there.
Feb 05, 2012 | Televison & Video
I could not connect to internet with my sony bravia kdl 32ex520 I am using the ethernet cable( no modem) when i check the status it is showing as cable is connected and internet is failed error 1106 i...
Ethernet connections between the tv and the computer into one signal frequencies are not compatible signals.Ur main home computer have internet service connection go through a wire or wire less Router for a internet signal through out the house.Connect the tv internet signal through the Router.Internet signal will work fine.
Aug 18, 2011 | Sony KDL46HX800 46 in. 3D LCD TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Connecting a computer to the tv
Philips Magnavox MS3652S will only connect to a computer with a converter (except if you have a video card that outputs to a TV compatible mode). You need a VGA to composite video (or S-video) converter. http://www.svideo.com/vgatotv.html for a few of the converters.
Computers output RGB signal; TVs do not read this signal. The video cards that can provide a TV-out signal directly come with a converter for the AV cables. (Check your manual for the video card. For some graphics cards with TV-out, see http://www.newegg.com/Product/ProductList.aspx?Submit=Property&Subcategory=48&Description=&Type=&N=100007709&IsNodeId=1&srchInDesc=&MinPrice=&MaxPrice=&PropertyCodeValue=2328%3A14103&PropertyCodeValue=2328%3A14101&PropertyCodeValue=2328%3A14201&PropertyCodeValue=2328%3A14104 .)
I hope this helps.
Jan 02, 2011 | Philips Magnavox MS3652S 36" TV
Problem just started. Getting na signal on TV.
1. Remove the video/display cable from both TV & Laptop.
2. Again Connect the two devices properly.
3. Press "Function Key+F5" to connect to the TV (External Display)
4. Also put your TV in "TV/AV" mode.
tell me if it don't helps...tc! :)
Jan 05, 2010 | Toshiba Laptop Computer Battery PA2510,...
Can i connect a dvid cable from the monitor to my flat screen tv hdmi to watch videos from my computer? Thank you Martin
the Flat Screen TV if has, a HDMI input, also has VGA Input.
You must choose :HDMI or VGA, if HDMI The VGA board must Have HDMI Connector, and you connect a HDMI cable to the TV.
The HDMI is a digital signal input/output, VGA is Analog Signal. You must have Signal Converter if you Use the 2 signals
Oct 31, 2009 | LG Flatron F700P 17" CRT Monitor
The tv will not let the computer connect to it
YOU HAVE YOUR RESOLUTION IS SET TO HIGH ON YOUR COMPUTER YOUR TV ONLY SUPPORTS 720P AND YOUR COMPUTER IS MORE THAN LIKLY SET HIGHER GO TO CONTROL PANEL>DISPLAY>SETTINGS LOWER YOUR RESOLUTION PROBLEM OVER...
Aug 09, 2009 | Sharp LC-32SB24U 32 in. LCD TV
I bought a vga cord to connect my acer aspire one to my 42 inch polaroid television and i got a signal for a minute then there was no signal can you please help
Hi There,
Please check the system up on the bios of your computer system to see if the system will support the tv, and also check the menu of your tv to see if the connection seeting are set for the computer input. They both must be compatable.
Please let me know how you get on.
Regards,
Philip
Dec 07, 2008 | Computers & Internet
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
85 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
