Question about Toshiba 42HPX84 42 in. HDTV-Ready Plasma Television
Flickering dots hundreds of small green and white dots flicker over the entire screen and are more visible with darker backgrounds.
  • Anonymous Mar 31, 2014
    Every so often, the screen flickers in a sort of strobe effect. It is only 4 years old and has seen some decent use but has not been abused. At times the problem will stop for a while but then start back up again. Any answers?
    Novelist:
  • 192 Answers
The symptom you described is called diffusion. A simple alignment, normally in the power supply takes care of this problem. For the nearest Authorized Service Center near you contact Toshiba online at: http://webmail.tacp.com/service/servcntr.nsf/$$Search?OpenForm Hope this helps
Posted on Jun 03, 2007
SOURCE:
I have Soney TV KDL-46EX713. Green lines come on/off the screen. Sometimes screen goes entirely green with background picture still visible. Sometimes only green lines flicker like in picture below.
Looks like power supply board fault. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Apr 17, 2016 | Televison & Video
My HP Pavilion Entertainment PC monitor background has been periodically changing from white to green and flickering. Someone said theirs was doing that and was told they needed to send it in to be...
Hi,Well your issue could be as a result of a faulty screen or a disconnected screen Connector(Flex).once you confirm these,and it is still flickering, locate online the nearest Hp service center and visit them to get it fixed for you.
Jan 12, 2011 | Microsoft HP Pavilion DV6276US Notebook PC
ASUS eee701 - Display is flickering in black/white version
If the entire display is flickering, tha'ts typically a hardware issue. Try tilting the screen back and forth, or pressing gently on the area just above the keyboard to see if you can replicate the issue. If it flickers then, you've got a bad cable or a plug.
It's unlikely, but if it is a software issue you can try dowloading new drivers for the video card. Go to the ASUS website, enter in your model information, and see if you can find drivers for the video component.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Hope that helps.
Mar 08, 2010 | ASUS Eee PC 701 Notebook
SyncMaster 213T Screen quality
did you try change the VGA cable? if not, try it.
Dec 19, 2009 | Samsung SyncMaster 213 T 21.3" LCD Monitor
When PS3 boots the screen turns green with white dots
Emergency cooling should be cleaned. If not cleaned, you risk expensive repair.
Oct 24, 2017 | Sony Playstation 3 (PS3) Console
Some black colors are replaced with red blue flickreing in whites
Hi there
Firstly reinstall the graphics drivers, if its still the same there is a problem with the graphics card and you'll have to have it looked at.
Good luck and thanks for using Fixya!
Feb 06, 2009 | Fujitsu LifeBook C2340 Notebook
Hitachi Plasma EDTV has green dots flickering all over screen
that is called diffusion. that can be adjusted out in most cases by adjusting the y sustain pcb but can also be the main pcb, the logic pcb and panel itself but not likely.
Jan 11, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Code displayed over my ps3 xmb, affects gameplay
video rsx cpu maybe partially damaged..i can probably fix it.
Nov 10, 2008 | Sony Playstation 3 (PS3) Console
Ghosting, Flickering, Green Sparkeling Lines, Color Washout.
There is a component failure on the board inside the display. Since you did not post the model number that is all that I can tell you.
Mar 17, 2017 | LG Studioworks 700B (White) 17 in.CRT...
Flickering then off
Problem is with Invertor Board maybe defective 2SC5707 transistors.
Samir
Jul 28, 2008 | BenQ FP71E 17" LCD Monitor
Toshiba 42HPX84 42 in. HDTV-Ready Plasma Television Logo
461 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
