Question about Refrigerators
Fridge not cooling.freezer defrosted.ice in vents between fridge/freezer.water in evap tank.outside of fridge is still warm
  • 2 more comments
  • billykoala Jan 09, 2009
    fisher&paykel fridge/freezer model #e442brx c. fridge not cooling. freezer defrosted.ice in vents between fridge/freezer. water in evap tanks.fridge still warm on outside.less noise than when working properly. HELP!!!!!!!!!!
    anymore suggestions other than defrost mech gone bad ?
    dont kno if solution helpful yet. havent heard anymore suggestions
    problem fixed by defrosting ice build up in vents between fridge/freezer.as usual we should always look at the simple problems. DOH !!!!!!!!!!!!
    Master:
  • 416 Answers
It might be sevaral reasons: Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Good Luck
Posted on Jan 09, 2009
  • 716 Answers
You Have A Drain Plug In Your Freezer Make Sure It Is Clear All The Way To The Drain Pan Underneath You Most Likely Will Have To Remove The Inside Back Panel Of Your Freezer Check The Fan If It Stops The Fridge Gets Warm No Matter What Settings You Put It On. The Drain Plug Will Also Be Back There On The Bottom. Just Check To See If Its Covered In Gunk. Grease The Fan And Spin It With Your Finger Once You Have Unplugged The Fridge. Grease The Fan Then Spin Spin Spin By Hand Add A Little More Grease And Then Plug It Back In. A Good Indication That The Fan Is Seized Is You Dont Hear It When You Open The Freezer.
  • 180 Answers
Defrost timer is likley gone bad.
  • 4,472 Answers
First off how long have you owned the fridge? What is the model number of the refrigerator? Once I have more information I can assist you further.
Thank you,
Lee
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 15, 2011 | Microwave Ovens
Ice forming in the top freezer, leaks in the bottom refrigerator section
Sounds like the defrost circuit of your fridge has failed. If you remove the back panel of the freezer compartment, you will see the evap coil encased with ice. Normally the defrost circuit will turn off the compressor and turn on a heater to warm the coil to about 45 degrees to melt any frost build up. After about 40 minutes the compressor will kick back in to keep your fridge cool again.
The typical failures are that the defrost heater burns out. If you have an older fridge, the defrost timer fails to advance, causing the fridge to stay in cooling or defrost mode.
May 27, 2011 | Kenmore 18.2 cu. ft. Top Freezer...
Maytag side by side fridge freezer leaking water
Your drain plug within the evap area of the freezer is frozen, turn frig off, let sit for day or two with doors open. Once all ice has melted then take rear freezer evap cover off and pour water into try and make sure it drains, if not then unplug drain. This is usually caused by a defrost heater bad or unit not going into defrost when it's supposed to, may be main board.
Sep 30, 2009 | Maytag Sovereign 60 Side by Side...
Freezer works fine but fridge has lost its temperature.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 02, 2009 | Refrigerators
Freezer is frosted in back Refrigerator is warm
The problem is the defrost system located behind the freezer back panel.
The defrost system (AKA evap. system) is composed by an heating coil, a fan , and a defrost thermostat, and its function is avoiding ice formation on coil.
When defrost system is defective the fridge wont cool down properly
In your fridge , either evaporator fan, thermostat or heating element is faulty, and the ice on coils is preventing the appliance from cooling down properly.
Mar 29, 2009 | Hotpoint HSS25GFP Side by Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Warm Fridge side
Defrost the fridge freezer overnight. Restart unit. If it starts working you have either had a door ajar or a defrost problem. If it fails to cool down at all then you may still have a defrost problem or a evap fan motor faulty. Most likely outcome is that the unit will work once defrosted for approx three weeks after which the freezer will freeze back up. Most likely cause will be the defrost heaters. Any good tech should be able to help on second failure. Hope this helps.
Sep 05, 2007 | Whirlpool GS6NBEXRS Side by Side...
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
