Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Broken 360?
By mikeaguilar on Jun 03, 2007
Hello fellas. Alrite here is what happend. I was playing NBA 2k7 and i wanted to hear some music. I plugged in my zune and the game froze, So i turned off and on the 360. It wouldnt load past the menu . then id get a green screen and more freezing. Now its too the point where all i get is the flashing 4 lights. Not even a menu or anything.
I called in to get some help. They tell me i have no warranty . i tried complaing telling them how i supported them since day 1 cuz i bought it on launch. but they didnt budge. they want to charge me 130 bucks.
suggestions?
thanks
Solution #1
posted on Jun 18, 2007
Not Rated)
cheebster
Rank: Wiz
Rating: 88%, 83 votes
Hi there. The xbox 360 suffers from overheating, and different symptoms can be seen after the board has 'warped', from overheating.
Basically, the video processor chip and/of the video memory chips gets disconnected from the main board from overheating. The behavior of the console can be many things, from the '3 Rings of Death' which consists of the console not even starting up with the 3 front lights flashing, to occasional freezing, lockups, video artifacts and lines.
You might notice a difference in the console's behavior depending on the actual temperature of it. If it freezes on each startup, even on a 'cold' boot, the board is probably bad enough now.
If you're really out of luck with getting MS to replace it, you might try the 'towel' method. It's still better than using the xbox as a doorstop.
I won't be describing this technique here as it's a bit weird, but you can find it on xbox-scene.com forums, searching for 'towel' might get you some tutorial on it. It basically consists of blocking both the air intake and exhaust of the console, which makes the internal temperature so high it actually 'reflows' the connection between the graphics processor and the board. That worked for a few guys it seems, but it's far from a 'by the book' technique, to say the least. :)
Hope that helps, cheebster.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my xbox 360 has one red light. how can i fix this
Answer
1 red light bottom right unable to clear can not play
Answer
Whilst playing a game, the colour changed to a pinky colour. I switched the console off and there is... (More)
Answer
my xbox 360 is running but not displaying any picture it is not showing ring of death but the... (More)
Answer
when unplugged and then replugged in the console will not turn on but the fan runs constantly... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Xbox 360 Console:
Top Video Game Console Experts
Rank: Guru Guru
Solutions: 384
Experience: From previous experience, research, schooling, and studying the work.
Ask Me
Find more Video Game Console Experts
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
