Question about Pioneer DEH-P4700MP CD Player
Wiring My husband is trying to hook up the radio, but lost the manual. He is not sure what colored wires go to which speaker and so on. We are tryin to insert in a 2007 chevy.
  • chris63125 Nov 07, 2007
    Need radio wire info in a 1996 S10 Blazer so I can match up to the one I am installing...a new chrysler factory stereo/cd player...which colorc go together??
The wires coming from the radio should be this: Yellow = 12v constant Red = Ignition Black = Ground White = (Left?) Front + White w/black stripe = (Left?) Front - Gray = (Right?) Front + Gray w/black stripe = (Right?) Front - Green = (Left?) Rear + Green w/black stripe = (Left?) Rear - Purple = (Right?) Rear + Purple w/black stripe = (Right?) Rear - Orange = Illumination (DO NOT ATTACH THIS WIRE) Blue = Power Antenna (only attach if you have a power antenna) As for going to the chevy, the wires vary by the specific vehicle & I wouldn't want to guess. Also note that if it has a factory amplifier, it'll be a bit harder. I suggest he gets a wiring kit from Circuit City. It's about $15 or so, but well worth it.
Posted on Jun 03, 2007
SOURCE:
I need a 2000 nissan sentra wiring diagram because my pioneer stereo was hooked up wrongn and now have no dash lights
I can provide the radio wire colors and each function of the wires by color. 2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Feb 28, 2018 | Nissan Cars & Trucks
Trying to connect rear speakers in a car to the car raadio. Not sure what wires go where. I am looking for a wire ddiagram for a goodmans raddio serial number G- 172200 0229. Please can you help?
I recommend you purchase a wiring harness specific to your vehicle. Then you can hook the radio to the harness. The harness will have the color code on the package. All aftermarket radios have standardized color coding.
Aug 27, 2011 | Car Audio & Video
Trying to install a new radio into my 95 toyota 4 runner but the wire colors in the car and ione ones on the radio don't match. how do i find out what wires to hook to what
if your truck still has the plugs from the stock radio you can buy a wiring adapter from walmart, if not you will have to test each one individually, black is always the ground red and yellow will be the power leads yellow is usually constant but test both with a test light or voltmeter with the key in the off position and the the on position to make sure. As for the speakers you will have to hook them up one at a time and make sure the sound is coming from the correct speaker. possitive and negative wires for each individual speaker will be the same color, but the negative will have a stripe runing down it. Hope this helps.
Mar 29, 2011 | 1995 Toyota 4Runner
I have a 2002 olds alero and im tryin 2 hook my
Ok to start you need to go to this website and you will have to get the factory adapter for your radio so it can be modified.
.http://www.installer.com/cars/by_car.php?carid=4267 and also check this site this wiring diagram will help.
http://www.modifiedlife.com/2002-oldsmobile-alero-car-radio-stereo-audio-wiring-diagram/
Apr 16, 2010 | Car Audio & Video
I need the radio wire color code or wiring diagram
two purple wires, speaker
two white wires, speaker
two gray wires, speaker
two green wires, speaker
black wire, ground
yellow wire, battery...for memory( goes to a constant 12V power source)
red wire, ignition, to pwr on when key is on
blue wire(remote wire if you have a system)
Mar 18, 2010 | Chevrolet C1500 Cars & Trucks
Ok, here is a list of the factory wires coming from the car that I have for hooking up a radio and there colors. Red wire with blue stripe, red wire with yellow stripe, brown wire with white stripe, brown...
Hello jlharris28, Here's the color code for the '92 Sentra: Radio Constant 12V+ Wire: Red/Black Radio Switched 12V+ Wire: Blue Radio Ground Wire: Chassis Radio Illumination Wire: Red/Blue Radio Dimmer Wire: Red/Yellow Radio Antenna Trigger Wire: N/A Radio Amp Trigger Wire: N/A Front Speakers Size: 5 1/4′ Front Speakers Location: Doors Left Front Speaker Wire (+): Blue/White Left Front Speaker Wire (-): Blue/Yellow Right Front Speaker Wire (+): Brown Right Front Speaker Wire (-): Brown/White Rear Speakers Size: 6 1/2′ Rear Speakers Location: Rear Deck Left Rear Speaker Wire (+): Red Left Rear Speaker Wire (-): Green Right Rear Speaker Wire (+): Blue Right Rear Speaker Wire (-): Pink It's better to use an aftermarket wiring harness that plug into the vehicle wiring. The Metra part number 70-1763 seems to be the correct one for your vehicle. Hope this helps.
Aug 12, 2009 | Car Audio & Video
I need to find the colors for the rear speakers to hook up a amp
2003 Mercury Sable Car Radio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Green/Yellow
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Jun 02, 2009 | 2003 Mercury Sable
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Need help with wires
This is from a 2004 Solara, but it's probablly the same.
2004 Toyota Solara Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Dark Green
Car Stereo Dimmer Wire: White/Green
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
May 25, 2009 | 2006 Toyota Solara
Pioneer DEH-P4700MP CD Player Logo
124 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
