Question about Siemens Gigaset A120 Single Dect Cordless Phone - Black
PROBLEM WITH THE BASE GIGASET A120
There is an indication to my hand phone 'problem with the base'.it's an new device,almost 1 month.what should i do?
    New Friend:
Thank you for these instructions. I have Siemens geigaset A120 with three handsets and one of the handsets stopped working about a year ago and my previous tries att registering it at the base station had failed and I was about to give up and buy a new set for 80 Euro, but I decided to give i one more try at registering and it worked the third time around. So do not give up. When one your hand sets stops working (no dial tone and can not call from it) try re registering as described above.
Posted on Jan 31, 2015
SOURCE:
  • 518 Answers
SOURCE: Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Posted on Jan 23, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
  • 518 Answers
SOURCE: siemens gigaset 4215
Then the base is bad. I have 1 base like that also... nothing can be done other than send it out to be rebuilt.
Sorry,
Geno
Posted on Mar 22, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 9 Answers
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Posted on Dec 26, 2008
How do I fix my phone?
Try another handset usually portable phones can have 2 3 or 4 handsets in the kit one is unusual if the second handset works then the phone is faulty usually the internal antenna cord has become dislodged which stops it being able to send or receive via the base
Solution 1 remove the battery cover & battery the remove the screws that retain the back cover of the phone & look around around for loose or dislodged connections.
Solution 2 get a 2nd hand phone off ebay (same make and model)
sychronise it with the base & if that works toss the faulty one
Solution 3 theses are relatively cheap Good Guys in Sydney
had Philips & Unident 3 phones & bases for under $50 recently
Solution 4 Get someone like me to repair the phone but it is likely to cost more than a new one to repair it, Pick a solution 1, 2, 3, or 4
Jan 11, 2015 | Lands Phones
My panasonic kxtg441 won't charge (just 1 handset)
Hi just take a pencil eraser & rub the phone contacts on both the hand set & the base where they make contact. This should work.
Aug 20, 2014 | Lands Phones
Base
What model AT&T DECT 6.0 phone?
Jun 24, 2013 | AT&T DECT 6.0 Cordless Phone System with...
Uniden xdect 7015 won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jul 28, 2012 | Uniden DECT 6.0 Cordless Telephone...
Additional handset on BT Synergy 6500 phone is stuck on 'Test Mode'
is possble to use 8 bt 6500 hand phones via 2 base unit on the one bt line
Feb 28, 2012 | GE 25942GE2 Cordless Phone System
Uniden base flashing 88 8
I just got off of the phone with Uniden for the same issue with my D1680-4. The alternating "8" - "88" code is an indication that the base is dead. They will be sending me a new base (and 2 handsets). During the call I learned that if you do not have a receipt, Uniden warrants their phones for up to 15 months. The advertised 12 months, plus 3 months for the product to get from manufacturing, through distribution channel and finally sale to the consumer.
Feb 17, 2012 | Uniden D1680 Cordless Phone
I just got the Jabra GO 6470: The desk phone doesn't ring in the headset, so if you're not within hearing distance of the desk phone (but within the 300 foot range of the base) you don't know...
what i gather from what you have said is that the headset doesn't ring at all. this would indicate to me that the headset is not paired with the base.
normally when pairing devices the base station will look for the device but at the same time you will have to hold the headset power button for at least 5 seconds for that the other device can capture the signal.
i will look into this for you but try this method if applicable but the bluetooth devices do have to be paired in order to work.
Jun 15, 2011 | Jabra GO 6470 Wireless Headset with Touch...
I have just inherated the at&t e5634b phone system. I have replaced the batteries in the hand sets. As per the manual I have de-registered each hand set. The problem is that when I register the...
This problem can be caused by the following, A bad battery, (which you say you are all new). A full base memory and a Faulty main base unit
This main base unit can only expand to four handsets and no more. If the base unit has been reset then the assigned numbers for each handset would begin with " handset 1" if they show any other number when reset then it would not have been reset..To re-set main base you will have to
De-Register All Handsets
Unplug the power supply from the base unit then Remove all handsets from the charge cradles and base then Press and hold the PAGE button on the base.
Plug in the power supply again while pressing the PAGE button, Continue pressing PAGE until the IN USE and CHARGING indicators are lit. (this could take up to 10 seconds)
Release the PAGE button All Handsets will display "enter base id".
If this does not solve your problem then you will have to replace the main base
Apr 20, 2017 | AT&T E5634B Phone System w/ Caller ID
Sony SPP-A946 base unit intermittently charges the hand set.
Clean the contacts on the handset and base that charge the battery.
AL
Mar 17, 2009 | Sony SPP A946 Cordless Phone
Siemens Gigaset A120 Single Dect Cordless Phone - Black Logo
5,610 people viewed this question
Top Siemens Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
