Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Colman Furnace keeps kicking on & off
I have 1974 mobile home with a colman furnace model # 7995A656 and it kicks on and off at night and wont stay running. I have restarted it, cleaned and changed the filters, oiled the fan and motor. What is wrong with it. Is it going to be expensive to fix.
    Problem Solver:
  • 6 Answers
Denise, my heater not a coleman (a monitor heater (oil) kept turning off when the temp got really cold. I would advise you to ask if you can do this, I addded an additive to my drum outside which holds the fuel. Because the deisel thickens up when it gets cold, which makes the heater have a harder time distributing the fuel to the heater. So far the heater has not kicked off.
Posted on Jan 09, 2009
I have a 1984 Colman propane furnace that is short cycling
Why does the gas furnace short cycle - YouTube
? 11:07
https://www.youtube.com/watch?v=3LBut8fWcw8
Apr 23, 2012 - Uploaded by grayfurnaceman
When the gas furnace short cycles, and it does not bring the structure up ... have a frazier Johnson furnace with 9 blinks on diagnostic light. just ...
Mobile Home Furnace Troubleshooting - Mobile Home Repair
www.mobilehomerepair.com/articlefurnace.php
Jan 17, 2016 | Heating & Cooling
Why does my Colman EB10C electric heater start & run for a few seconds,stop, then restart & run?
check your high limit switch find blower motor and unplug white wire let furnace run it should shut off when hot enough if same problem replace high limit switch
Jan 04, 2013 | Coleman Mobile Modular Home Electric...
Question about efficiency of a colman electric furnace 3500A816. In a mobile home built in 1997.
Is this your main heating system for the mobile home? I hope these other solutions mentioned help but I would think you have to replace it since it is a 1997. Mobile homes get cold I wouldn't trust it if it does it again.
Nov 30, 2012 | Heating & Cooling
Model DGAA070BDT SER# 0112o6717 Colman Mobil home furnace My furnace makes a internal thump when it's in the cool down cycle after the burner shuts down and only the fan is running before the furnace...
Coleman is known for this. I have seen many over the years make this noise during cool down. The heat exchanger is contracting and expanding. The heat exchanger is the part that the fire burns in. It surrounds the flame, and when the furnace is on, the metal they use for many of their furnaces has a tendency to make noise as it cools off.
One other thing, if you don't already have one, it would be good for you to buy a carbon monoxide detector and put it in the mobile home somewhere up high hopefully in the hallway close to the furnace return air. If the heat ex. is expanding as is sounds, it would be good to make sure it does not have a crack in it , in turn releasing dangerous fumes. Hope this helps.
Apr 18, 2011 | Heating & Cooling
Draft blower stays on all the time on my Colman Evcon that is in my mobile home.What could I check for, any sensors? Furnace runs fine otherwise.
there is a temperature sensor in the fire box that keeps the blower going til it cools down after the burner shuts off, could be faulty and keeping the fan on
Feb 14, 2011 | Tools & Hardware - Others
We have a Colman Direct Vent Forced Air furnace, Model 7970A856, in our mobile home. We just moved in. We cannot get the pilot to light.
thermocouple is bad, thats the little probe that sits in the pilot flame, and runs back to the gas valve
Oct 23, 2010 | Heating & Cooling
Mobile home furnace
you probably have a bad thermostat if it wont shut down id replace the thermostat first and then have the thermocoupler checked...replace the thermostat
Aug 20, 2008 | Heating & Cooling
Colman furnace
look on your burner control relay - look for terminals marked T and TH.  connect up a honeywell thermostat here.
Oct 03, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
311 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
