Question about Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind
Manual and automatic mode
I want to use the timer in Manual mode and Automatic mode when needed. I can't seem to see that there is this type of option. I assumed it would have these features.
  • Eager4 Feb 08, 2009
    Thank you, but this timer works differently. It has three buttons verses the large button. I see no manual or automatic buttons in this model.
  • 37 Answers
I believe if you hold down the large button with the circle on it for a few seconds, it will operate in manual mode. If you just push that button once, it will turn on manually but only till the next programmed hour, then it goes back to automatic.
Posted on Jan 24, 2009
Well that is amazing that if the button is held it does actually work on this model too. It takes about 4 seconds and a black dot appears and over rides the mode. Excellent advise sparky 2021.
Posted on Mar 28, 2009
Turn off light
what type of camera or model you are using ?
when the camera is set to automatic mode by default the flash flickers as it calibrates the amount of light needed to capture the picutre
try to set the camera on manual settings
or if you set the camera timer on once you click the shutter button the timer will then count down and a light will blink so turn of the timer
Mar 28, 2014 | Cannon Cameras
I need a Diablo Sensor Timer Stw-1 manual
Per sticker on top of the device: To place in Automatic mode, quickly switch lamp ON-OFF-ON again. Timer will turn lamp OFF in 2 seconds and red light will be on. Timer will now turn lamp on for time cycle when dark.
Dec 14, 2013 | Hardware & Accessories
How do I use the automatic timer setting on my camera
Press the MODE button until the one-handed clock appears in the status LCD.
Full details are in the "Using self-timer mode" section of the manual (page 35 in my copy). If you need a manual, you can download one at
http://h10032.www1.hp.com/ctg/Manual/bpl51337.pdf
Sep 18, 2011 | HP Photosmart 735 Digital Camera
Cooking time button - does the oven shut itself off adfer the prescribed time???
I assume you are talking about an electronic or manual timer. Either timer will turn the oven off after the time expires. These timers must be in automatic mode and not manual mode before they will do this.
Feb 06, 2011 | Whirlpool Accubake RF362LXTT Electric...
For GE- 15117, Mode acts as a controller called "an On or Off override..." "or sets events to Automatic or random" Random = a +/- program shift (that's understandable). You'd think...
I cannot make precise sense of your question.
However I agree, the manual for GE 17117 is not clear.
1) A number of folks are writing in about this particular timer, with same MODE problem as you.
Some folks, the timer skips over auto.
Some folks the timer just doesn't come on.
Facts are facts, some timers are busted on arrival.
But let's look at the problem from three different directions and see if it helps:
2) Steps from manual:
When you finish programming, press clock button to return to current time.
Next set MODE.
Press MODE button and timer enters override ON-OFF. Override reverses whatever program is operating at that moment.
Press MODE button again and timer enters RDM random mode, and lights turn on-off randomly.
Press MODE button again and timer enters AUTO >>> auto is correct setting that lets programs run.
Here's the trick: after setting MODE to auto, press clock button again and current time displays.
If timer will not perform these steps, then timer is suspect
If timer performs these steps, but programs won't work, the timer is suspect or programming is suspect.
3) Check programming for conflicts and overlaps that cause timer not to function 'as expected.'
Some timers skip over conflicting programs, some timers simply stay on, others stay off.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
Example of conflict is event1 ON at 7am TU > but event1 OFF at 11pm All-days. Both event1 ON and OFF events must have consistent days >>> so change TU to All-days.
Another example is event1 ON 7am OFF 11pm TU >> but event2 says opposite, or has overlapping times.
I suggest folks make a schedule of programs before starting.
To review and change programs, start with current time showing in display: Press PROG button and scroll through event1 ON, event1 OFF, event2 ON, event2 OFF, etc.
Write down the events and make a chart.
Look for overlaps, and check for days of operation, and make sure each event ON has corresponding event OFF
4) If events are correct, and timer MODE button functions, but timer still doesn't work, the final suspect before calling the timer busted, is circuit problem. Use circuit analyzer on receptacle. Or plug timer into receptacle on different breaker and see if problem persists.
Dec 11, 2010 | GE Hardware & Accessories
I have set program 1 on and off times and program 2 on and off times but do not know what mode to choose to get it to work!!
People are writing in with problems about HB88RC.
Problems seem to revolve around MODE button and setting automatic for timer to operate programming.
One guy said his timer skipped over automatic.
Another fellow today reported that timer programs would not work.
So maybe your timer has similar problem.
I'm going to e-mail Intermatic with recent information.
I need clarification on your exact question.
Intermatic generally e-mails back and is concerned with their products and customers.
That being said, let's look at your timer problem.
When you finish programming 1 and 2, press Clock button to exit programming and current time shows on display.
At this point, timer should function.
According to manual:
If you press MODE button once, timer will enter override, and lights will turn on.
Press MODE button again, RDM shows on screen and timer enters random mode and lights turn on-off randomly so it looks like folks are home.
Press MODE again and timer returns to Automatic and programs 1 and 2 should run.
Add a comment and let me know what is happening so I can report to Intermatic.
I will post results on this thread.
Dec 03, 2010 | Intermatic HB88RC - 7-Day Programmable...
I programmed the timer as instructed but when the time to turn on came it didn't turn on. I changed the mode to "on" & it turned on but I don't think it will turn off automatically. What...
You posted under Woods outdoor 2-outlet timer 59403:
Add a comment if this is not your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Lets run through trouble spots others have with programmable timers:
Add a comment any time and I will help.
What we know for sure:
-Battery is working because display shows.
-Manual override works, so basic electricity is OK and light is OK
-Common programming problems:
-You set current time and it shows in display > if current time is not set or does not advance with passing time, then timer does not know when to turn on-and-off. Double check display for current day, hour, and minute.
-Each event has ON time and OFF time. So you set event1 ON and then set event1 OFF. For example some people set ON time and don't realize each ON needs corresponding OFF, or can't find how to set OFF. Trick is making sure timer display matches fig3 and fig4 shown in manual. Press PROG button until display shows 1ON for event1 ON and then press PROG button until display shows 1OFF for event1 OFF.
-To review programs and double-check, press PROG button repeatedly to scroll through programming. Check for ON and OFF days, and for overlapping on-off commands.
-Event1 ON and event1 OFF should be set for same day(s). For example event1 ON is set for Tuesday but event1 OFF is set for All-days (instead of Tuesday) will conflict and timer will not function.
-Conflicts in programming will cause problems. Conflict example: Event1 says ON 7pm OFF 9pm Tues, but event2 says opposite.
-Make schedule of on-off times before programming to avoid conflicts.
Setting Mode:
MODE is manual override button: press it to set Automatic, ON-OFF override, or Random
Press MODE button until RDN displays in upper left corner, and then press MODE one more time to enter AUTOMATIC >>> you want automatic for programming functions.
Circuit analyzer: If above items check out 100%, and timer still doesn't work, plug timer to indoor plug on another circuit (not on outdoor plug). This will check if outdoor plug has electrical problem interfering with electronics inside timer. Buy cheap plug-in circuit analyzer from Home Depot electric department and double-check circuits.
59403 manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
Nov 27, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
I have a intermatic ej351c indoor wall switch programmable timer that I have tried several time to program an on time for the lights to come on however the lights does come on. I have followed the...
There might be a couple things that are easy to overlook.
Press the button to see if lights come on >>> if light do not turn on with manual override, then light might be burned out or circuit breaker tripped. Sometimes a breaker is tripped but you can't tell by looking at it
1) The timer is used on incandescent bulbs only. I don't know why, but it says no
  • Compact Florescent
  • Energy Saver
  • Flood lights
  • Halogen
  • Mercury Vapor
  • Christmas lights
  • Candelabra bulbs
2) Is the red indicator light ON?
For programs to work, timer has to be in automatic mode and the red indicator light will be ON
The Switch Timer can be used in two modes. manual & automatic
To switch between modes, quickly press the dial twice:
AUTOMATIC MODE: The Switch Timer will turn your lights ON or OFF according to programmed settings. The RED indicator light stays ON when in Automatic Mode.
MANUAL MODE: Programmed settings are inactive, and
the Switch Timer will only turn the light ON or OFF when
you push on the dial.
RED indicator light stays OFF when in Manual mode.
3) setting current time> lets look at the red indicator light while doing this
Move switch lever to OFF-Clear
Move lever to ON >>> red indicator is flashing
Rotate dial to nearest current time (if it's 7:20 pm, rotate dial to 7:30pm)
Press the dial once to set current time > red indicator light goes off
Do not accidentally press dial or it will set the wrong time....ok we know that
4) overlapping programs/
Make a chart of the times you want to program with ON and OFF plus am & pm
Check your chart for overlapping times that tell the timer to do more than one thing
Rotate dial clockwise to the first ON time >> pay attention to am & pm
Press button and first ON time is set
Rotate dial clockwise to the first OFF time >> watch the am and pm
Press button and first OFF time is set
You can have 48 on-off times >>> which seems a lot for a 24 hour repeat timer
5) try the timer with one program
6) If timer still doesn't work, put switch back in and see if lights turn on that way >>> it could be a loose wire suddenly cropped up
Last step >>> timer is no good, you need another one. We tried.
Oct 16, 2010 | Electrical Supplies
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind Logo
200 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
