Question about MA Audio HK4000D Car Audio Amplifier
Ma audio hk 4000d
Blue powerr light comes on led digital screen with temp and volt meter the fan lights n evrty thing
hooked up my two 18 inch ma audio subs 1100 watts peak 550 rms
no sound or anything thought subs were bad maybe but i hooked my memphis 15,s to it no go and the memphis were playin on another amp as of yesterday so sum thin is wrong with the amp every thing comes on except no sound from the subs
  • 15,935 Answers
You have definately blown a output channel, or power supply. Send it in for warranty.
Posted on Jan 09, 2009
Led doesnt light on cuel automatic climate control
not sure if it is the same as mine but mine had 2 lights behind temp control setting if one is burned out that might be why it is so dim. also my lights were not led they used regular bulbs so when I replaced them I put in led lights I got off e-bay. if the lights are working you likely have a bad connection somewhere you can try hooking a volt meter up one side to the positive on the battery and the other on the negative on the light if that reads good reverse it hook one end to the negative on the battery and the other to the positive on the light and see if it reads good just make sure there is power to the light socket when you test it. if one side is showing low volts that is likely the bad side and you will half to start checking wires on that side
Jul 12, 2015 | 1995 Buick LeSabre
Want to attach a harbor breeze light kit to an existing hunter fan. switch housing has 3 white wires hooked together with a blue connector cap and a single black and white wire(labeled for light). there...
White to white ( single white ) & blue from light kit to Black with white stripe. Also make sure the black with white stripe coming out of TOP of fan is connected to the hot wire.
Aug 26, 2013 | Hunter 52" Ceiling Fan With Light And...
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
Sanyo CLT2054 - power cord has light but when I plug it into the
OK you need a volt meter to check the voltage output of your power pack as two things cause this now enough power out the pack to run your unit or the unit has a short both problems will unlight the light so you need to know if the power supply is working right first as it should say like 120 volts AC in and 12 volts DC 1000 ma out so you will need to mesure this with a volt meter. this is a common problem loading the load of the curcuit as in your TV is mor the the power pack is giving out thus shorting out the power pack of any voltage present, as the little LED light your seeing only takes 5 volts at very ittle current to light and dose not repersent the total voltage output of the power pack itself
May 16, 2009 | Sanyo CLT2054 20 in. EDTV-Ready LCD...
Need to pick perfect amp
I suggest to use separate amps to your sub, get a 2 channel amp for your sub and 4 channel amps for your speakers.
Here are my Top 5
  • Lanzar -OPTI4000D
  • MA Audio- HK-4000D
  • JL Audio 1000/1V2
  • OPti 22.2 Power Amp
  • AudioBahn-A5100T
Apr 05, 2009 | Power Acoustik FUBAR-12W Car Subwoofer
Fan light kit will not function
Have you taken a VOM (Volt-Ohm Meter) and checked to see that the "two wires" of which you speak actually have 110-120VAC on them?
I bet they don't and I bet they don't because "up top" (where the connections in from the ceiling box, the BLUE wire (might be brown on some fans) is not hooked up. Unless you have separate switches at the wall, the blue and black wires coming out of the fan must be combined and hooked to the BLACK wire coming out of the ceiling box. White (neutral) goes to white, and green goes to ground.
Good luck, and always OBSERVE practicable safety precautions.
Mar 06, 2009 | Hunter 23827 Classic Original White 42"...
My ma audio hk 4000 amp is powered on no sound coming thru subs amps brand new
If there is no protection light on, be sure the input is on. Some head units need to be turned on manually (factory set to OFF).
Verify the subwoofers are wired properly.
A list of your components would help to solve your problem.
If it is new, it should still be under warranty - worst case scenario output transistor(s) blown, or power supply bad.
Jan 09, 2009 | MA Audio HK4000D Car Audio Amplifier
Amp is powering on at all
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Aug 16, 2008 | MA Audio HK4000D Car Audio Amplifier
MA Audio HK4000D please help me ?
Turn the system off and disconnect the speakers. Turn the system on. If the amp still goes into protection mode with no speakers connected, then most likely the output transistors are bad. If the protection light is off, hook up one sub at a time until you find the one that is causing the problem
May 21, 2008 | MA Audio HK4000D Car Audio Amplifier
LED power protection light not turning on
Check the fuse on the amplifier; if it's good, then you need a multimeter or voltmeter for further testing. With the meter's black probe on your amp's ground terminal and the radio turned on, both the power and the remote terminals should test at about 12 volts. If neither terminal shows voltage, you may have a problem with your ground connection; if both do, there's a problem with the amp.
Feb 20, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Open Questions:
MA Audio HK4000D Car Audio Amplifier Logo
242 people viewed this question
Top MA Audio Car Audio & Video Experts
Mark Skinner
jamie suver
Level 1 Expert
Robert Rankin
Are you a MA Audio Car Audio and Video Expert? Answer questions, earn points and help others
