Question about Western Digital Protege WD200EB 20 GB Hard Drive
Hard Drive I have 3 different hard drives - two of them state that primary and secondary disk drive can not be found, one says diskette drive seek failure...any thing I can do to fix this? can't even log on to windows.
  • 47 Answers
Make sure they are set to main hard : Master on one cable
2nd : slave on the same cable as the first hard drive
3rd : as master or cable select on the second cable
windows should load then
Posted on Jan 09, 2009
Diskettedrive 1 seek failure primary hard disk drive 1 not found secondary hardisk drive 1 not found cp says strike f1 but cp boot only up to xp logo then re start again and so on again and again
If both of the hard drives are on the same data cable/disk drive controller it is unlikely that both the have failed. Reseat the data cable connectors on the hard drives and at the motherboard.
Reboot you computer and hopefully it will boot up.
Check the BIOS configuration to see if the BIOS detects the hard drives.
If not the disk drive controller on the motherboard may be faulty.
Aug 26, 2011 | Dell OptiPlex GX150 PC Desktop
OptiPlex GX150 series. Diskette Drive 1 Seek Failure. Primary Hard drive 1 Not found. Secondary Hard drive 1 not found.
Sounds like a hard drive failure. It is fairly easy to purchase a new hard drive and put it in, but then you must have the software to re-install everything. If you are a bit concerned about doing these things, take your PC to a PC Repair shop and they will install a new hard drive and put a new operating system on it. Depending on how old the Desktop is, you may want to buy a new PC as the old motherboard may fail on you in the next 6-months to a year. Check your gut on this.
Oct 29, 2010 | Dell OptiPlex GX110 PC Desktop
When i start my computer it says press f1 to
This means your hard drive has either failed or is disconnected.
Given the age of the computer it's most likely the drive has failed.
Let me know if there is important data saved on the computer. Otherwise, replace the drive and re-install windows and it should work again.
Crankstart
Jan 08, 2010 | Dell OptiPlex GX150 PC Desktop
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Diskette drive 1 seek failure is shown on when the computer is turned on primary hard disk drive 1 not found secondary hard disk drive 1 not found.
Hmmmm That is strange.
If all three of these error messages started at the same time it probably means that something has seriously gone wrong with the Input Output controller(s) on your motherboard.
Have you moved house recently? Sometimes cables can fall off inside the computer when you move them although it is unlikely that your floppy and hard drive cables would both fall off.
When the computer starts go into the bios settings the button you need to press normally flashes up on the screen. Like F2 or Del or something like that. If the date and time is wrong the battery on *********** board may have gone flat. Not a big deal to change that.
Otherwise you may be stuck.
Sep 16, 2009 | Dell OptiPlex GX110 PC Desktop
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Hi! my computer doesn't start normally it goes back to the same error every time. Errors: Floppy diskette seek failure Drive 3 not found: Parallel ATA,PATA-1 (PRI IDE Slave) Strike the F1 key to conti
Sounds like you have a bad/disconnected Hard Drive and the system is looking for a second boot device (ie: Floppy with a disk) or your primary IDE channel on your motherboard is bad
Apr 16, 2009 | Dell Dimension 3100 PC Desktop
Boot into setup by pressing F2 or F10 depending on your bios and disable the floppy drive setting.
Jan 14, 2009 | Computers & Internet
Hard disk failure
What exactly does the error say?
The safest thing to do is to stop powering up the hard drive. Get a new hard drive and adapter cable to pull the data off the old hard drive (secondary) and onto the new hard drive (primary) after the new hard drive has been formatted.
If you don't feel you can safely do that, you may want to seek the assistance of someone who can or a company that provides hard drive recovery services.
A hard disk failure error typically indicates the hard drive has (or is about to) fail and become useless.
Jan 03, 2009 | Computers & Internet
Diskette drive 0 seek failure
Try removing the motherboard battery...wait for about 10 seconds...replace it and try again
May 10, 2008 | Smartdisk - Peripherals - HARD DRIVE,...
Western Digital Protege WD200EB 20 GB Hard Drive Logo
85 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
