Question about Euro-Pro 382 Mechanical Sewing Machine
The upper thread no longer catches the lower thread
All of a sudden I cannot get my upper thread to catch and bring up my lower thread. I have taken apart the bobbin and made sure the tension on the bobbin was correct. Any ideas?
    Genius:
  • 1,116 Answers
Check the needle to be sure it is installed per the manual.
This is usually with the flat side of the shank facing the back of the sewing machine.
Last resort - take the machine in for service as it could be the timing needs to be adjusted.
Posted on Apr 01, 2010
My brother computerized sewing machine does not catche the bottom thread to make a stitch
try using a longer needle, or lowering the one you have now by loosening the needle screw and dropping the needle down some
Aug 08, 2014 | Brother Sewing Machines
Top thread keeps catching on bobbin
check for sufficient thread clearance between bobbin case finger and locating slot. in other words it must be free to allow the thread to pass through and complete the stitch
Mar 01, 2014 | White Sewing 935 Mechanical Sewing Machine
Big loops under the needle plate. The bobbin case is pulled towards the needle and lifted up in the front.
OK, Nylon thread and vinyl fabric are difficult. Try this:
1. Be sure your machine is *very* clean - no leftovers from previous projects.
2. Take the bobbin receiver out (need a screwdriver to hold the release), clean it and all around it and re-insert. When you re-insert in this machine, hold the release lever with the screwdriver, push the receiver away from you (under the feed dogs) then bring it back toward you so it catches before you release the catch.
3. Use a stitch length just a bit longer than you 'normally' would - 3+ for vinyl.
4. Wind your nylon thread onto a bobbin *very* carefully. It's easy to get it caught so that it won't feed evenly.
5. Be sure your upper thread is in properly, and that it doesn't catch on anything.
6. Adjust your upper tension tighter than 'normal' to accomodate the slippery thread your're using - do this a little at a time, it's easy to miss the 'sweet spot' if you adjust too much.
7. Be sure to bring up your bobbin thread and hold both threads as you start to sew - hold them for 3-4 stitches.
8. Sew slow - this machine can go *really* fast, but don't let it on this project. It will catch better if you take it slow and easy.
Hope all this helps. If not, you'd probably better take it in for service.
Aug 29, 2012 | Singer CG590 Mechanical Sewing Machine
Upper thread will not catch the bobbin thread
make sure to use every thread guide
try a new needle
make sure the bobbin is inserted correctly
if these suggestions don't help & if the machine is still under warrenty take it back & let them check it
Mar 20, 2012 | Singer Sewing Machines
My Brother XL-3022 sewing machine has been running perfectly for years, then all of a sudden today I went to use it and while threading the machine I am not able to get the upper thread to draw up the...
There are a few easy and free things to check:
1- try a new needle 2- check that the needle is inserted the right way (one side has a long slot, usually this goes toward the back of the machine) 3- flip the bobbin over 4- clean any stray threads/fluff in the bobbin area
Another possibility is that the machine's timing is off- the bobbin thread isn't in place to be picked up at the right time- and that would need to be fixed by a sewing machine mechanic. But if this started suddenly, and not after hitting a pin or otherwise jarring the machine, then it probably can be solved with one of the easy/free solutions above. Good luck!
Mar 05, 2011 | Sewing Machines
The upper thread is not catching correcttly. When it does feed through the bottom corectlly it jams up after about an inch of sewing. It jams up with tons of thread.I have threaded and rethreaded cleand...
check to see if you have your needle in backwards
have you checked your needle to see if it's bent-roll it on a flat surface & see if it rolls good
check to see if the needle is blunt-makes a popping sound when going thru fabric
check to see if the thread is getting caught on the notch of the spool of thread
check to make sure the bobbin is not warped
check to make sure there are no burrs on the bobbin case
check your upper thread tension
Aug 21, 2010 | Singer 3116 Simple
Drawing up the lower thread
Check the needle to be sure it is installed with the flat side to the back of the sewing machine.
Mar 03, 2010 | Brother LS-2125 Mechanical Sewing Machine
I cannot get the needle to catch the bobbin thread
sounds like your keeping the upper thread too tight when you drop your needle down to catch the bobbin or the bobbin thread that you left hang out is too short, let me know if it works amy
Jul 25, 2008 | Brother LS-2125 Mechanical Sewing Machine
Bobbin thread won't catch
I've just had this exact problem with my model 2037. The problem, according to 3 shops I've taken mine to, is that the shuttle hook (the metal piece that the bobbin sits in) is broken and needs replaced. Problem is, the piece is next to impossible to find.
Jan 14, 2007 | White Sewing 2037 Mechanical Sewing...
Euro-Pro 382 Mechanical Sewing Machine Logo
187 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
