Question about Microwave Ovens
Emerson MW8993RD Microwave under yr old quit working
I have had it 9 months. Bought at target retailed for 149.99 and we went to use it one morning and noticed it was plugged in but not lit up. Like it had no power what so ever. Any ideas whats wrong or how to fix?
  • soldierlover Jan 09, 2009
    I cant find the receipt so I assume they wont fix it. Someone said its prob the fuse. Any ideas how to find it or where i can get a schematic?
  • Microwave Ovens Master
  • 9,086 Answers
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or call 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
In case you don't have yours, many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you .
Posted on Jan 09, 2009
  • William Miller
    William Miller Jan 10, 2009
    OUCH! That hurts!
    Actually most manufacturers will honor the warranty with the model & serial number, or if simply sign an affidavit stating when you purchased it.
    You'll never know if you don't contact them.
    It
    may be the fuse, which is usually located behind the grille, on
    the
    floor of the oven behind the control panel, between the door switches,
    or on the filter board near where the cord comes into the unit.
    It will be a 15A or 20A ceramic fuse, either gray or white.
    You should be able to
    get one from a home center or local appliance parts store.
    If
    the fuse is good, it may be an open thermostat or thermal cutout (TCO)
    / thermal fuse on or near the magnetron or on top of the cavity / body
    of the oven.
    If it went dead almost
    immediately after pressing the Start pad, that's usually a shorted
    high-voltage capacitor.
    If it went dead several seconds after pressing the Start pad, that's usually a failing
    high-voltage transformer.
    If
    it goes dead or blows the breaker (or GFI) when you plug it in or open
    or close
    the door, then there's a problem with a door switch or door switch
    mount.
    If you need other parts, I would refer you back to the contact links in my solution above.
    We're
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
Our microwave oven started making a loud sound and quit heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Microwave Quit Heating
The Magnotron goes out on many of the lower priced models in the first yr.,(and some of the higher end ones too!) As the components there do most of the hard work. Better to just find a recycler who takes them and scrap it.
As for the replacement that sounds like an excellent idea!
Sep 02, 2017 | Emerson MW8778 Microwave Oven
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Emerson Microwave MW8119SB not turning on
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating an authorized servicer or parts at 1-800-695-0098.
Dec 08, 2008 | Microwave Ovens
Microwave not turning on
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If you still have trouble, since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
Aug 09, 2008 | Emerson MW8107WA Microwave Oven
Microwave doesnt heat anything.
it is the door problem it seems to be known issue per target sales guy he advise to call emerson since it is past 90 days for target to return
Jan 19, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
