Question about Delta 10"Hybrid Tablesaw with 30"Unifence
Burning electric tool brushes
I just changed the brushes in my Delta tablesaw and I'm still getting alot of flash coming from the motor. There doesn't appear to be a particular way to insert them. Do you have any suggestions? Thanks, MR
  • 132 Answers
There is suppose to be some flash coming from the brushes. If there is no flash then the tool will not work
Posted on Feb 02, 2009
Delta 36-600 table saw new belt run's and sounds great, BUT wont cut butter?? Any help would be great thanks. Oh could it be brushes?? Cheers Matt Blade is in the right way,Delta 36600 have brushes.
Not to insult your intelligence, check the blade direction. Looking at the tablesaw from the left side, the blade should be turning clockwise and the teeth cutting downward. Also the teeth should be very sharp. Typically a belt run tablesaw doesn't use brushes but a capacitor to start rotation. You didn't mention if the blade turns when started. Since you mentioned it sounds good when started I'd rule out the motor. Some saw blades have an arrow to indicate direction. Hope this helps. Good luck.
Oct 28, 2017 | Vacuums
Smoke come from motor and now drill hardly moves .is new motor required or brushes
You will rarely get smoke from the brushes on electric tools. Smoke is usually a result of either the armature or field coils getting hot enough to melt or burn the varnish insulation off the wire which results in a loss of or no power because of shorting in the windings. You'll have to replace whichever part burned the windings and find out what caused the problem or you'll burn the new part the same way the original burned.
Mar 01, 2013 | Drills
MY ROCKWELL 10 INCH TABLESAW SUDDENLY QUIT WORKING. IT TRIES TO COME ON WHEN I HIT THE START BUTTON, BUT BLADE TURNS 1/4 INCH THEN STOPS. CONTACTOR STILL HUMS THEN THE BREAKER TRIPS. PLEASE HELP!!
If the blade turns freely by hand,check the motor brushes.Most high quality power tools have easily replacable brushes,and they usually only cost a few bucks.
Sep 15, 2012 | Delta Saws
"..... 52" unifence When turned on, the tablesaw
Hi, have you considered that the brushes on the motor could be needing replacement? Hope this helps.
Nov 15, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Please walk me through troubleshooting electrical problems on my 34-761.... not a breaker not the fuse in the starter unit.Had clogged(stopped) motor cleaned and gone over.I had it running just great for 8...
Common problems are motor brushes on direct drive saws and also the switch. The switch takes a lot of surge current and often burn the contacts. Troubleshoot with a voltmeter or ohmmeter.
If power cords are flexed alot, they can break at flex points.
Aug 10, 2010 | Delta Saws
The brushes are gone in the motor of my mastercraft tablesaw
Send me your email address with the model # and Type (1,2,3 etc..) and I'll help you get them. Send request to: desertairrepair@aol.com.
Feb 08, 2010 | Delta 10"Hybrid Tablesaw with 30"Unifence
Bosch 4000 tablesaw won't start. Brushes replaced
I found that the remaining problem was a intermittent at the switch, which disassembly and cleaning resolved.
Tilting the motor / blade assembly down allows access from below, to the 3 screws fastening the controller circuit board cover on the brush end of the motor. From there, one can easily test exposed wires for power supply, see that brushes are contacting and clean accumulated sawdust.
Jan 06, 2010 | Bosch Electric Table Saws
Where can i buy a new motor for delta table saw model no; 36-525 and how much or is it cheaper to buy a new one
Buy the motor from Sears, Tractor Supplies, Northern Tool, some large ACE stores, and some home improvement stores.
Sep 18, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Motor not working on Delta table saw: I just got a used Delta table saw for free, the previous owner said the motor wasn't working. I wonder if it could just be a switch... how could I check that? I also...
Ok, the motor turns, but throws sparks on the brushes. This is normal to an extent for universal motors used on that type of equipment.
Try reassembling the saw, and put a blade on it, then try it. If it runs, try cutting a piece of scrap 1x, both crosscut & rip. If the motor can't hold the load, you may still have to replace it.
Apr 16, 2009 | Delta 10"Hybrid Tablesaw with 30"Unifence
Delta 10"Hybrid Tablesaw with 30"Unifence Logo
131 people viewed this question
Top Delta Saws Experts
Jim London
Jim London
Craig Butler
Craig Butler
Are you a Delta Saw Expert? Answer questions, earn points and help others
