Question about Haier GDZ5-1 Electric Dryer
I need a belt for a Haier GDZ5-1 - Haier GDZ5-1 Electric Dryer
    Scholar:
  • 58 Answers
Contact sears parts and ask for
part # wd-0350-32
retails for 4.99. Good luck
Posted on Jan 09, 2009
4 Suggested Answers
SOURCE: Haier dryer GDZ5-1
I ordered the repair manual and it is completely worthless.
Posted on Aug 20, 2008
hunter19_46m
  • 7482 Answers
SOURCE: Haier GDZ5-1 spins but wont heat up. can I fix
Sounds like your problem may be with the heating coil.
If you plan to try to repair the problem yourself, then the first thing you want to do is unplug the dryer from the electric.
Remove the back of the machine and try to locate the air duct going from the blower to the drum. Normally inside the air duct you will find the heating coil and the thermostats/thermistor.
Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause a fire, as you have removed the saftey of overheat from the machine.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Posted on Oct 19, 2009
jyackle5
  • 8197 Answers
SOURCE: I don't find a belt for my Haier GDZ5-1 dryer, i
You can get parts for the dryer on the link below. part 5 or 6 down.
http://www.partstore.com/SearchResults.aspx?q=GDZ5-1&x=48&y=12
Good Luck.
Posted on May 31, 2010
Haier dryer makes grinding noise and drum not turning. Drum turns by hand but not when turned on.
belt probably broke and tangled around motor --will need to open rear panel to see if belt broken or popped pulley
Jun 15, 2016 | Haier Dryers
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
Haier dryer RDE/RDG 350AW
Replace the drive belt must have slipped off maybe loose from use.
It does say in manual to store and move in an upright position.
Sorry don't have a reapir manual but crack it open, and either fix the belt if it has slipped off its tension pulley or you will need to replace the belt just did my LG dryer last weekend a 4 out of 10 difficulty,,,about 1and half job....belt costy me $25.00 hope this helps some.
Jul 23, 2014 | Haier Dryers
NEED TO REPLACE THE FAN BELT ON HAIER DRYER MODELHLP140E
Remove the lint trap. There is a bolt in the center. Remove bolt. Remove screws from crossbar and you can then replace the belt. I removed sensor and lifted drum out makes it easier. Pay attention to how black belt is thread if removed
Apr 04, 2014 | Haier HLP140E Electric Portable Dryer
I don't know how to replace the fan felt.
I own the Haier Dryer and found the red/orange fan belt by searching part # WD-0350-37 @APPLIANCE PARTS DEP(-APPLIANCE PARTS DE DALLAS TXUS. The part was cheaper than the other places and the shipping was actually slightly lower. Now putting the belt on was a bit tough. I finally figured out that I needed to remove the bolt inside the dryer with a ratchet.
Mar 08, 2011 | Haier HLP140E Electric Portable Dryer
How do i replace belt on Haier HLP021WM portable washer? It doesn't spin on its own, but if i give the machine a little push, it will spin. Is this belt problem? I put the machine on its side and can see...
I have the same issue. Upon removing the back access panel I can see the motor spinning but the belt has become stretched and is not spinning the drum. I ordered my belt, I assume it will fix it. Probably needs done once a year if used regularly.
Jan 22, 2010 | Haier Washing Machines
My haier hw-c-1460 washing machine continuously throws its drive belt off of the pulleys. What is causing this?
Have you checked the tension on the belts? Loose belts will exhibit this symptom.
If they're loose the procedure for tightening them is not very difficult -- let me know if you want help with this...
Charlie
Aug 13, 2009 | Haier Washing Machines
Haier GDZ5-1 Electric Dryer Logo
174 people viewed this question
Top Haier Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Haier Dryer Expert? Answer questions, earn points and help others
