FixYa.com
Tags:
Toshiba TheaterWide 62HM94 62 in. Rear Projection HDTV Television
Toshiba 62HM14 (by 2 users)
posted by janoo123 on Jun 03, 2007
in my TV i get sound & red light on in front panel. After few seconds green light start blinking & it goes off
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Dec 19, 2007
red and green lights blink continueously and cannot see the picture after replaced a new rear almp
Best Solution
posted on Sep 07, 2007
FixYa! (100)
cammykins
Rank:Wiz Wiz
Rating: 82%, 143 votes
Here is some useful information off of the manufacturer's product information PDF regarding the lamp problems/issues:
LED indications:
The green and red LED lights on the TV control
touchpad (on the lower right corner of the TV screen)indicate the TV?s current status, as follows:
? Green ON = Control touchpad being pressed.
? Red ON = Power ON.
? Green and/or Red blinking
35) Special care for D LPTM (digital light processing) units:
? Lamp?The lamp in this product has a limited service life.
The length of service life varies depending on product use or user settings. If you use the lamp beyond its service life:
- you may notice a reduction in the colors and/or brightness of the picture, at which time you should replace the lamp unit; and - the strength of the quar tz glass in the lamp will be reduced and the lamp may rupture. If the lamp ruptures, the TV will not operate until the lamp unit is replaced.
Here is more info:
LED Indication Condition Solution:
1) Green lights solid; Red blinks at 0.5-second intervals.
2) Green blinks at 0.3-second intervals; Red lights solid.
3) Green and Red blink at 1-second intervals.
4) Green is off; Red blinks.
5) Green and Red blink three times. The lamp unit door is not seated properly.The lamp is not working properly. The lamp is not working properly after the eighth
automatic restart (see item#2). For service personnel only.
An abnormal temperature increase has occurred. Turn the POWER OFF and unplug the power cord. Review ?How to replace the lamp unit? on pages 57?59 to ensure that the lamp unit door is installed securely. If the problem persists, contact a Toshiba Authorized Service Center.
The TV automatically will try to restart itself eight times.Turn the POWER OFF and then ON again. If the problem persists, replace the lamp unit (see pages 57?59). If the problem still persists, contact a Toshiba Authorized Service Center.
Turn the POWER OFF: and unplug the power cord. If the problem persists, contact a Toshiba Authorized Service Center.
Do not block or cover the slots or openings in the TV cabinet. If the problem persists, contact a Toshiba Authorized Service Center.
_______________________________________________
I hope this helps you out!
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 06, 2007
Thanks for Trying (70)
leslake
Rank:Wiz Wiz
Rating: 82%, 134 votes
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Can you Help with these Projection Televisions problems?
Toshiba TheaterWide 62HM94 62 in. Rear...
Lamp replacement problem
I just replaced the lamp in our... Answer This...
Humming sound from Tv
62hm94 Toshiba...hearing a... Answer This...
Humming sound
Getting sound from my Toshiba.... Answer This...
Toshiba TheaterveiwHD 2000...
This very large TV was given to... Answer This...
wavy picture
I have 65" HD projection... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
