Question about Car Audio & Video
How do I connect a JVC receiver to the ignition switch?
I am replacing the OEM radio with a JVC cd player.  JVC support says that it needs to be connected to the ignition switch to operate properly.  The wiring harness does not connect it.  Where is the connection for the ignition switch?  One other site said to run a wire to the fuse box.
  • blueextc3221
    blueextc3221 May 11, 2010
    Please reply with your car make/model so I can help you locate a switched power source.
    Thank you
  • 4 Answers
You need to get a testing meter, connect the black lead from the testing meter to the car ground. and one to the pin in the connectors. Do this with the car ignition switch on, find one that's live, then turn the ignition switch off it should go off. then just cut the wire and connect it together. make sure you have a good ground lead connected to the ground of the car.
Posted on Jan 11, 2009
Resets when I turn ignition off
The yellow wire on your radio needs to be connected to an always hot fuse or wire. It is hooked to one now that is connected through the ignition, which is why it won't keep settings.
Feb 17, 2014 | JVC KD-G120 CD Player
I set radio stations and when I shut the car off, I lose my presets.
The yellow wire in the wiring harness of your head unit must be connected to a constant power source, a live terminal in the fuse block that is connected to the battery and not affected by the ignition switch. If you do not have your manual this may help: http://resources.jvc.com/Resources/00/00/95/GET0182-002A.pdf
Mar 22, 2011 | JVC KD-G200 CD Player
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
My radio wont turn on what wires do i need to check
most aftermarket radios red wire has 12 volts when the ignition switch is on and yellow (memory) has 12 volts all of the time
Nov 12, 2009 | JVC KDG320 In-Dash Satellite Radio CD...
I have the same model cd player (jvc kd-s575) and I need to connect this straight to a 12v battery. What is the best way to do ths and what wires are positive and negative?
im bit confused, if you are going to use this radio in car, or outside, using car battery.....? anyway, this how you hookup all the wires..
+YELOW WIRE,- DIRECT FROM BATTERY TERMNIAL..12+
+RED- MAIN WIRE..CONNECTED TO ACC/IGNITION SWITCH, ALSO 12V+
-BLACK- NEGTIVE, GROUNDING WIRE 12V-
WHITE TO WHITE/BLK----SPEAKER
GREEN TOGREEN---SPEAKER
GREY TO GREY-----SPEAKER
PURPLE TO PURPLE------SPEAKER
if you are using outside the car using car battery, then you can twist yellow and red togather..for postive 12v+
Oct 26, 2009 | JVC KD-S570 CD Player
How do you store radio station in memory?
you have the constant power wire and switched wire backwards.
Switch the red and yellow wires around.
Thanks for using FixYa - A FixYa rating is appreciated!!
Feb 16, 2009 | JVC KD-HDR1 CD Player
Jvc kd s 6060
You need to swap the ignition live and permanent live around. If you have a vauxhall the car stereo wiring is the opposite way round to everyone else! Some Rovers have it aswell.
Jan 11, 2009 | JVC KD-S6060 CD Player
JVC car radio/cd player wont switch on
As a sanity check run a temporary wire directly from the battery positive to the radio. Twist the red and yellow wires together and connect it to the wire from the battery. If this works either your red or yellow wire connection under the dash or to the harness is not hot like you think. Yellow usually goes to a constant 12 volt source (to keep radio memory) and the red wire to 12volts when the ignition is on. In some radios this is reversed. The test I mentioned will determin if the problem is in the wiring or the radio.
Jun 18, 2007 | JVC KD-S570 CD Player
Car Audio & Video Logo
154 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
