Question about Fossil Arkitekt watch
REMOVING LINKS FROM FOSSIL ARKITEKT MENS WATCH
IT`S TOO BIG, AND I NEED 2 OR 3 LINKS REMOVED
  • 2,334 Answers
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 09, 2009
HOW TO REPLACE BATTERYIN MY FOSSIL ARKITEKT WATCH
Take your watch to a jeweler for battery replacement.
Feb 15, 2014 | Fossil Arkitekt watch
Fossil AM3695 Wrist band
http://www.ebay.com/itm/FOSSIL-AM3695-BIG-TIC-KALEIDO-BROWN-LEATHER-MENS-WATCH-/150793269174
Jun 13, 2012 | Fossil AM3695 Wrist Watch
How do i take a link out of my stella watch?
mcdevito75 here, Genearlly removeing the bands links are more common with Mens watches but some womans watches also have this option, the links are held together with pins which require a link pin remover tool so these pins don"t get bent. Best Bet is to look for a small watch repair shop in your araea and have them remove a link or two, also hold onto these removed links in case you need them again.
Feb 11, 2011 | Fossil Stella Topring Watch
I am trying to find extra links for the band, it is too tight, I need 2. I have searched all the web sights I can find with no luck. The watch is a Fossil ARKITEKT FS-3003.
You can get links from the maker.
Go to http://www.fossil.com/en_US/shop/customer_care/static/fossil-customercare.html and you will see a menu on the left.
Under "Product info" you will see "ordering links and bands", click on this and follow the instructions.
Jan 08, 2011 | Fossil Watches
Can't get back off to change battery, even with special tool
Looking at the Fossil site, I couldn't find "Arkitekt blue" as a description.
I noted that they have a blue one which is automatic (i.e. self winding) and therefore does not need winding - but it does need to be worn to keep the spring wound up.
The Fossil site has a complete list of their models and selecting one gives you all the details of the watch, including manuals.
I suggest you try a search on the web site.
Jan 02, 2010 | Fossil Arkitekt watch
Lengthen band
to make longer have to add a link-contact them 800-842-8621 will ask for info on back of watch
Nov 26, 2009 | Fossil Arkitekt Stainless Steel ! Watch...
Need links for fossil kaleido Ll2097
Fossil will provide you with links at no charge if the model is not too old and they have the parts.
The 800 number is in your owners manual.
Feb 19, 2009 | Fossil NCAA Kaleido Washington Kaleido...
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Fossil jr9339
I can only give a general guide.
Usually, watch bands can be shortened by removing links. These links are commonly held together by small pins. These need to be removed with a very fine punch. Looking at the ends of the pins, one end commonly appears "split", the other end may look quite smooth. The pin needs to be driven out from the "split" end. 2 will need to be removed to remove 1 link, then 1 replaced to rejoin.
Links should be removed equally, so gar as possible, from each side of the band. Your choice which side if 1 only is to be removed.
Sometimes the ending links are different to the others. It is only the ones that are identical that can be removed.
May 31, 2008 | Fossil Watches
Fossil Arkitekt watch Logo
637 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
