Question about Sonic Impact Technologies iFusion Video v55 (490571015754) Remote Control
Okay im having a problem with my sonic impact v55 portable i cant see my videos but i can hear it through the speakers. before this, i had an ipod video 5th gen. now i have an ipod classic. it worked before but not now... what do i do to fix this?
  • Anonymous Jan 31, 2009
    I have the same problem. Only this started from the beginning and I have a 5th gen 80 GB iPod
I'm sorry, but the bottom line is that you cannot watch videos on the V55 with a 5th gen iPod. 4th gens work fine though. Apple made this change in their iPods after several aftermarket companies began losing money in their products not selling. In response, iPod apparently teamed up with those companies and installed a chip to "decode" the video content. You can hear audio, but see no video. It stinks, I know. I am just glad that I have a 4th gen video iPod.
However, I am posting here because I am looking through posts and blogs to find out how to fix my V55 as the screen is intermitently going bad.
Posted on May 26, 2009
I've been told that a COMPOSITE APPLE AV cable is needed, plugs into the side of the F55 & you will get video. I just ordered mi cable, it shipped yesterday & I will post as soon as I test it.
Alan
alevine@bellsouth.net
Posted on Jul 17, 2009
The sound has stopped working on my sonic impact I fusion and I have no idea why please help
the part were my ipod plug into Sonic Impact i-Fusion is very loose and at times will not play music- I need to put presser on the ipod to play music - how can I fix this loose ipod plug in?
Aug 24, 2010 | Sonic Impact Technologies i-P23 Portable...
My sonic impact technologies sonic impact video 55 can not play my movie I don't not why. I hear my musie but can not see my movie on the screem. what can i do
If you have a later IPod, 6th Gen or later, Apple changed the software and Sonic Impact no longer plays your movies, but audio is fine. You can get around this by purchasing, from Apple, and adapter cable. It is $50 but allows you to charge your Ipod and play your movies on your home TV. The cable is really just a key that unlocks the TV Out setting. If you have and 5th Gen or earlier then you probably just need to go into video setting and select TV OUT : ON. I hope this takes care of your issue.
Nov 11, 2009 | Sonic Impact Technologies Sonic Impact...
I have a Sonic Impact V55 Video player and a new 160GB Ipod. Anyway to get the video to work on it?
Absolutely, I have this myself. My 5th Gen works great, but the 160GB would not show movies, just played music. Apple has an adapter cable set that allows you to hook your Ipod to your TV. $50 buy it! You can charge and watch your stuff on your flat screen. It also unlocks your Ipod TV out setting for your Video 55. Set you IPOD video setting to TV Out: on, select your movie and play. Plug in the IPOD nip to your Ipod then set your Ipod into the Video 55. A bit of a pain but works flawlessly. If you select a different movie you have to do this all over again.
Oct 30, 2009 | Sonic Impact Technologies Sonic Impact...
Hello: My V55 worked perfectly when I put it away a few months ago... now, I hear the audio from a video, but no picture. Are there settings on the ipod to switch around?
I'm pretty positive that the iPod will 'just work' when you plug it in to a device like that.
Since you said it was working perfectly a few months ago, I would suggest you clean it out as best as you can. Take it apart, blow it out, clean the connectors with isopropyl alcohol (the highest % you can find) and clean the connectors on the ipod too.
Do you perhaps have another device to test the video output on the iPod on? Do you have another iPod you could try in your V55? Try switching things around and see if you can narrow down the problem.
Aug 21, 2009 | Sonic Impact Technologies iFusion Video...
New unit doesn't charge IPOD when plugged into 110v
make sure you have the cord plugged in to the DC IN 9V outlet in the speakers and not the audio in. Sounds simple but this is what I was doing wrong.
Jun 09, 2009 | Sonic Impact Technologies i-P23 Portable...
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
Mar 04, 2009 | Sonic Impact Technologies Sonic Impact...
Contact info for sonic impact technologies???
I found a website that had the phone # of their head of Technical Support (http://www.waves.com/objects/pdf/press/press_sonic_impact01.pdf ) It appears his name is “Big” Rich Bracke and his # is (760)944-0274.
Feb 03, 2009 | Sonic Impact Technologies i-P23 Portable...
I purchased a sonic impact video v55 for my daughter. It will play her audio files from her ipod but not her videos. She gets this error on her ipod: TV out enabled, please connect video accessory
Ok, i found out i do have a 5th generation ipod and i went to the apple store and the problem was i had to set my ipod video settings to TV Out to ON and TV Signal to NTSC then set to widescreen ON and the tech plugged it in and she worked like a charm, hope this helps
Dec 25, 2008 | Sonic Impact Technologies iFusion Video...
Sonic Impact Technologies iFusion Video v55 (490571015754) Remote Control Logo
321 people viewed this question
Top Sonic Impact Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
jscuin6
Tom Chichester
Are you a Sonic Impact Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
